carb/cam????
billyfresh40
ok, lets start at the beginning..... i got an 87 LX car last october. it was a 4cyl. auto. over the winter i played around and now its a 5.0 5spd.... i ripped the whole computer wiring harness out, and changes the cluster to a 90-93 style, with the 140 speedo.... this requirede some wiring but not part of the problem.....
the motor i put in was out of a 91, and after a slight tear down i saw it had roller lifters, so i'd imagine the cam is also a roller..... it was an efi but now is a carb.motor....
when i free rev the engine it sounds good, it is clear and i have it timed 10* advanced, with the vac. accel off. when i get onto the street, however, the motor chokes and breaks up until about 3000 or so, and then wakes up and spins through 3rd gear. the motor is strong but needs tweaking....
here's whats on the motor:
holley 650 street aveneger carb, fed by a holley elec. pump and 3/8 steel fuel line from the tank to regulator to carb, eldebrock performer 289 intake, accel distributor, msd ignition and coil, bbk shortie headers....
i havent fine tuned the fuel, which i think its just running too rich, but i was wondering if the carb/cam combo would be giving me a problem, since the cam is just a stock efi cam....
im also going to purchase ford racing wires to compliment the ignition, since the plugs and wires are still stock. im also buying reg. autolite plugs, platinums are junk and turn to crap once u get fuel on them...
any info would be appreciated..... thanks
no, it just breaks up at low rpm's, when it wakes up it runs awesome and then when i stop it idles fine, just 1st pulling out or "normal" driving. when u beat the snot out of it it runs great, so thats y i think 2 much fuel, like i said i havent fine tuned it yet, but i was hoping that the carb/cam combo would work..
