Just finished my vic jr install on my 351w. When i went to fire it up it wouldn't idle unless you keep bumping the gas. When i do this the accelerator pumps give a little gas and the car stay's running. If you stop doing that even with the idle screw turned in a long ways the car dies. I removed the 2 bolts in the side of the carb to look into the float bowls. With the electric pump on no gas would come out them. I thought that was kinda strange. I tapped on the float bowl on the rear then gas started coming out. no luck with the front bowl. I unscrewed the power valve bolt a little in the front and got gas right away. Can someone please tell me what is going on? Is the float stuck? before i took my engine apart the engine was idling good. It had sat all winter but car was idling at 700rpm after it got warm. what do i have to do to get the car to idle so i can set the timing?
