carb size help?
  • Thread starter Thread starter p0prcksandc0ke
  • Start date Start date Oct 12, 2007
p0prcksandc0ke
111
sacramento,ca
Oct 12, 2007
  • Oct 12, 2007
will a 600cfm carb be fine on my 390 bigblock just for daily driving, i had my aluminum intake and heads taken off so its almost stock ( till i can afford a new hipo one )
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Oct 12, 2007
  • Oct 12, 2007
If it's mostly a stock engine, It should work OK.
p0prcksandc0ke
111
sacramento,ca
Oct 12, 2007
  • Oct 12, 2007
ok good cause i need one but dont have money for a nice new one right now
2bav8
2,511
Mesa, AZ
Oct 12, 2007
  • Oct 12, 2007
You'll be fine...
M
mikethebike
358
Greenville, SC
Oct 12, 2007
  • Oct 12, 2007
Assuming the carb is right...it will work very well on a stock 390....now on a 428 CJ, that would be a horse of a different color.
p0prcksandc0ke
111
sacramento,ca
Oct 12, 2007
  • Oct 12, 2007
im glad its going to work hes dropping it off tonight and his shop just rebuilt it, i plan on getting a better one like a barry grant or something when i get the money
D
D.Hearne
11,730
south louisiana
Oct 12, 2007
  • Oct 12, 2007
Why'd you remove the aluminum intake and heads in the first place? Don't make sense to me.
p0prcksandc0ke
111
sacramento,ca
Oct 12, 2007
  • Oct 12, 2007
there was a crack in the bolt hole for the distributer so i got a stock one for free and it didnt want to go on correctly with my aluminum heads, so we put the stock ones back on
D
D.Hearne
11,730
south louisiana
Oct 12, 2007
  • Oct 12, 2007
Why didn't you just have the crack welded ?
p0prcksandc0ke
111
sacramento,ca
Oct 12, 2007
#10
  • Oct 12, 2007
  • #10
they tried that but the heat just made the bolt hole bigger so they sent it off back to edelbrock
D
D.Hearne
11,730
south louisiana
Oct 12, 2007
#11
  • Oct 12, 2007
  • #11
You needed a more competent welder is all. Sorry for the questions, but it seems to me you end up spending more than you should in mechanic's fees.
p0prcksandc0ke
111
sacramento,ca
Oct 13, 2007
#12
  • Oct 13, 2007
  • #12
it was all done for free thankfully , im going to put the 600 one on tomarow any guesses on how far im going to have to unscrew the 2 screws? and how do i tell if its running lean or rich?
Fast63
717
#13
  • Oct 13, 2007
  • #13
Start at 2 turns out with both idle mixture screws, screw them in and out till it idle's the highest, or if you have a vacuum gauge, hook it up to manifold vacuum and turn them till you get the highest vacuum at an idle, but you should have them within 1/4 turn of each other.
p0prcksandc0ke
111
sacramento,ca
Oct 13, 2007
#14
  • Oct 13, 2007
  • #14
im not worries about the idle right now im talking about the other 2 screw to adjust if its runnign lean or rich
JDS68Stang
153
New York State
Oct 13, 2007
#15
  • Oct 13, 2007
  • #15
As a certified welder I'll second that.
p0prcksandc0ke
111
sacramento,ca
Oct 13, 2007
#16
  • Oct 13, 2007
  • #16
there was a crack going through the bolt hole the patch it up but then we couldnt find a bolt to fit it. cause of the crack going through it.
Fast63
717
#17
  • Oct 13, 2007
  • #17
There are only two screws that adjust anything, and they are for the idle mixture circuit. Follow my instructions for that. To tell if you are running lean or rich otherwise, you need to look at the spark plugs after a little run time, white being lean and black being rich. Tan = perfect.
The idle circuit affects the whole rpm range, but you should set it at what it likes at an idle and change metering rods/jets as needed.
D
D.Hearne
11,730
south louisiana
Oct 13, 2007
#18
  • Oct 13, 2007
  • #18
I assume you're still messing with an Edelbog. Get a manual on how to tune it. You need to take more time to learn the basics. Right now it seems to me you're groping around in a dark room. It pains me to see you this way.
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
C
Bored with my 73
  • Curtis Harper
  • Apr 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 23, 2026
RaggedGT
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 4:40 PM
manicmechanic007
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sunday at 10:32 AM
khanpa
K
