Maybe I'm just reading too much into the total BS line.
I'll try to get back to my original point - a Holley 600 CFM or better yet an Autolite 480 will work much better than a 500 CFM 2 barrel on a street driven daily driver motor. Again, I'm referencing a street driven motor with no gears, cam, heads, or torque converter. A smaller 4 barrel will run more efficiently and give you a better performance then that large of a 2 barrel.
My reason for starting in on this thread - Sticking a large carb on a stock intake will give you drivability issues and will not perform to it's optimal potential on a small stock street motor.
Getting off my original point and trying to give him some insight I went off on intakes and sizing - the Performer looks very simliar to the stock 289 intake but it is definitely larger. The ports and the runners are definitely larger. The runners physically drop lower into the lifter valley, that's maybe why it doesn't seem as obvious up on top. I have one myself and I have pictures of them side by side....
The Performer 289/302 has the same runner configuration as the stock 289/302 intake but has a carb flange height of 3.50/4.75". A performer RPM is still a dual plane but has a different runner configuration and a carb flange height of 4.30/5.50". In other words, still larger runners. Bigger runners at low RPMs = low air velocties and poor mixtures for combustion. My point on intakes was some improvement can be good but too much can also be bad. Yes the Performer RPM is not that much larger than the standard Performer. I was just trying to explain the reason for not going larger if you didn't need it. There are basic laws of physics involved in the operation of a combustion engine. That's why the winning racers are the winners and the guys who don't follow the mathmatics are the ones in 2nd place. To simplify my original 750 double pumper example, go larger. Dual quads on a street motor are a perfect example. Those look cool and sound great bench racing but those are strictly for high RPM use. That's an example of as where I was going with a properly sized vacuum secondary street combo will beat him everytime - on the street.
Efficiency = Power
The point of my original thread was, everything works as a package. Big intake runners, big cams, big carb ventuies, big valves in the head, big ported heads, steep gears, they all work great for high RPM racing and sound cool when you're bench racing. What I was trying to help him understand is going overboard in just one area can be detrimental to overall performance. Choose your parts realistically. Maybe you'll make more improvements later and maybe you'll need a bigger intake later. But everything is only as good as the weakest link.
Lets try another area. An easy example of a single "performance" change would be gears. Yes they're your biggest bang for the buck but again there are limits and everything is relative to the complete car package and how you're actually driving/using the car. The don't fear the gear crowd would make you think the taller the gear, the bigger, badder, faster, and quicker you'll be. 4.10s for racing my be great, but for street driving, they could be your weakest link. Unless your motor and car is set up to support the higher RPMs those gears will require, there are downsides. They may be great for racing, but for the street with a stock motor, you will probably quickly be out of your usefull RPM band. And, without an overdrive transmission, you loose high speed cruising and if you're using a 4 or 5 speed you'll be shifting at much lower speeds sometimes with 1st gear almost useless.
Everything works as a package and you're only as good as your weakest link. You must choose your parts wisely.......
