Carb the gas tank ?
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
I was wondering if the Mustangs fuel line were one piece? From the gas tank to the carb?
The reason why is because i need to move it so that i can get some tips put on.
if its just one piece then i was going to replace the whole thing, depending on how much the line would have to be moved.
Probably would just be better to get a new gas line anyway :shrug: It is 23 years old
also......... dose anyone know what size of belt i would need to bypass the smog pump? Or is there a way i can do it by measuring the belt then doing something with that?
thanks :hail2:
is that good enough grammar :shrug:
seeing as this is a 5.0 section and you're car is not a 5.0, Im not sure if people will know the specific belt size for running you're engine without a smog pump. And I agree try tech.
