You know guys....... I'm starting to look at the Trutrac Detroits. I'm not sure if I am ready to step up to the plate with a spool. Whatever I am buying, I am buying it this weekend, standby
As posted above....if it's a dedicated strip car, get the spool....(stronger than the detroit and cheaper too) You can even drive a little on the street with a spool....(i wouldn't do it with the big n littles though)
If it sees regular street driving, get the trutrac.
After much deliberating. I decided to go with the truetrac. I love driving my car on the street and I'd hate to be caught out in a rainstorm or whatever and be stuck or wreck out. Not worth it. We'll see how this truetrac holds up!
**EDIT**
I've got a detroit locker in my cougar and it's great. My brother's got a spool in his car and it's a bitsh to turn that thing. It fights you and tries to straighten the steering wheel when you turn.
Good Luck. BTW, where were you running went the "mortar" went off? Just wondering if you were at Reynolds last weekend. I was going to go but got inexplicably sidetracked.
I know of a Det that has over 700 passes at over 600hp. Durability is not an issue with THAT locker. hey man, flip the cash for something you will probably never have to replace on your level of race car. JMO
Truetrac isn't quite as strong but I hear they are holding up well. We'll see.
Tremec TKO II (.82 overdrive)
Spec Stage III Clutch
FMS Aluminum Flywheel
Steeda Clutch Cable, Quadrant and Firewall Adj.
Steeda Tri-Ax Shifter
Lakewood Scattershield
FMS Aluminum Driveshaft
Auburn Pro Diff. (BROKEN)
Detroit Truetrac (Waiting Install)
Moser 31 Spline Axles
FMS 4.10 Gears (BROKEN)
Motive 3.55 (Waiting Install)
MAC Rear Girdle
SUSPENSION
Front Sway Bar Removed
Lakewood 90/10 Struts
Lakewood 50/50 Shocks
Eibach Drag Launch Springs w/ Airbag
Wolfe Racecraft LCA
HPM Welded Subframe Connectors
HPM Driveshaft Loop
Moroso 3" Racing Studs
EXTERIOR
Harwood 4" Cowl Hood
Cobra Front Bumber
V6 Rear Bumper
Wingless
Bullitt Fuel Door
17x8 Bullitt Wheels
15 x 3.5 Weld Draglights
16 x 8 Pony Wheels
16 x 10.5 x 26 ET Streets
INTERIOR
MAC White Face Gauges
Billet Shifter Bezel
Billet Shifter Ball
Rear Seat Delete
Gutted Trunk
We will see how good they are at high rpm launches.... I can;t wait. Even though the 3.55 will slow me down for the time being. it will be interesting to find out the 1/4 mile times I get and the mpg I get to the track!!!!
