Caster adjustment issues
  • Thread starter Thread starter 66HertzClone
  • Start date Start date Jul 17, 2007
66HertzClone
428
Central New Jersey
Jul 17, 2007
  • Jul 17, 2007
I'm having some problems with getting caster set at 3 degrees positive on the right side of my car. The left side was done without any issue, however the right side is proving to be trouble.
I have these parts on the car, G/West tubular upper and lower arms, Cobra Automotive roller spring perches, OpenTracker adjustable strut rods, G/West 520# springs now trimmed one 1/4 of a coil lower, the Baer tracker bumpsteer kit, a recently installed lower eccentric kit, and Koni shocks.
I've set the left side tire with 1/2 degree of negative camber and 3 degrees of positive caster. The eccentric and adjustable strut rods made this very easy. When I started on the right side I set the camber and when I tried to set the caster found that the edge of the front tire comes in contact with the lip of the front fender as I approach the 3 degree setting. I started adding some shims to the front bolt of the upper arm in order to move the upper ball joint back to gain additional clearance. This required resetting the camber which I did. I rechecked the caster and still need more, I eventually had to remove the 3/8 thick plate behind the G/West arm to get the desired setting.
There is a difference of 3/16 of an inch between the front shim stack and the rear, even with this gross amount of shims, I can only get slightly more than 2 degrees without having the tire dangerously close to the lip on the fender.
Any tips of help with this dilemma? I was not at the shop for the drilling of the mounting holes of the arms but I'm beginning to think that the holes may be too far forward in the shock tower. This would explain the problems I'm having. I guess I could just go with the 2 degrees, but I'm concerned about the big difference between the stack of shims on the arm.
66HertzClone
428
Central New Jersey
Jul 17, 2007
  • Jul 17, 2007
I did use the adjustment on the strut rod in addition to the shims. I worked the tire back and forth in order to make sure it would clear the lip on the fender. I guess I could try another 1/16 or 1/32 shim and see what change that makes. No rolling the lip on the fender yet, but it was something I've thought about.
I just finished doing a search on CC, you have virtually the same problem. I didn't see a response from you on what you did to yours, well?
2bav8
2,511
Mesa, AZ
Jul 17, 2007
  • Jul 17, 2007
What wheel package are you using up front?
66HertzClone
428
Central New Jersey
Jul 17, 2007
  • Jul 17, 2007
Vintage 50 series wheels, 16x8 with the 4.5 backspacing and 225/50 tires.
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
