Cats And Smog System Question
dz01
285
10
Massachusetts
I've got a magnaflow system with BBK high flow cats. I just noticed the line that normally goes from the smog system diverter valve (left side of motor near header) to the cats is pinched off. Is there an issue or could this throw any codes since this line is no longer connected to the cats? I'm assuming this is pretty standard practice, but thought I would ask.
If the cat H pipe has a place for the air pipe, it needs to be connected.
Thermactor Air System
Some review of how it works...
Revised 6 Oct 2014 to add location of TAB & TAD control soelnoids
The Thermactor air pump (smog pump) supplies air to the heads or catalytic converters. This air helps break down the excess HC (hydrocarbons) and CO (carbon monoxide). The air supplied to the catalytic converters helps create the catalytic reaction that changes the HC & CO into CO2 and water vapor. Catalytic converters on 5.0 Mustangs are designed to use the extra air provided by the smog pump. Without the extra air, the catalytic converters will clog and fail.
The Thermactor air pump draws air from an inlet filter in the front of the pump. The smog pump puts air into the heads when the engine is cold and then into the catalytic converters when it is warm. The Thermactor control valves serve to direct the flow. The first valve, TAB (Thermactor Air Bypass) or AM1 valve) either dumps air to the atmosphere or passes it on to the second valve. The second valve, TAD (Thermactor Air Diverter valve or AM2 valve) directs it to the heads or the catalytic converters. Check valves located after the TAB & TAD solenoids prevent hot exhaust gases from damaging the control valves or pump in case of a backfire. The air serves to help consume any unburned hydrocarbons by supplying extra oxygen to the catalytic process. The computer tells the Thermactor Air System to open the Bypass valve at WOT (wide open throttle) minimizing engine drag. This dumps the pump's output to the atmosphere, and reduces the parasitic drag caused by the smog pump to about 2-4 HP at WOT. The Bypass valve also opens during deceleration to reduce or prevent backfires.
Code 44 RH side air not functioning.
Code 94 LH side air not functioning.
The computer uses the change in the O2 sensor readings to detect operation of the Thermactor control valves. When the dump valve opens, it reduces the O2 readings in the exhaust system. Then it closes the dump valve and the O2 readings increase. By toggling the dump valve (TAB), the computer tests for the 44/94 codes.
Failure mode is usually due to a clogged air crossover tube, where one or both sides of the tube clog with carbon. The air crossover tube mounts on the back of the cylinder heads and supplies air to each of the Thermactor air passages cast into the cylinder heads. When the heads do not get the proper air delivery, they set codes 44 & 94, depending on which passage is clogged. It is possible to get both 44 & 94, which would suggest that the air pump or control valves are not working correctly, or the crossover tube is full of carbon or missing.
thermactor-air-system-65-gif.50636
Computer operation & control for the Thermactor Air System
Automobile computers use current sink technology. They do not source power to any relay, solenoid or actuator like the IAC, fuel pump relay, or fuel injectors. Instead the computer provides a ground path for the positive battery voltage to get back to the battery negative terminal. That flow of power from positive to negative is what provides the energy to make the IAC, fuel pump relay, or fuel injectors work. No ground provided by the computer, then the actuators and relays don't operate.
One side of the any relay/actuator/solenoid in the engine compartment will be connected to a red wire that has 12-14 volts anytime the ignition switch is in the run position. The other side will have 12-14 volts when the relay/actuator/solenoid isn't turned on. Once the computer turns on the clamp side, the voltage on the computer side of the wire will drop down to 1 volt or less.
In order to test the TAD/TAB solenoids, you need to ground the white/red wire on the TAB solenoid or the light green/black wire on the TAD solenoid. The TAB and TAD solenoid are located on the passenger side shock strut tower. Uneducated owners sometimes remove them to get more HP. This does not work, it just causes 81 & 82 codes.
For 94-95 cars: the colors are different. The White/Red wire (TAB control) is White/Orange (Pin 31 on the PCM). The Green/Black wire (TAD control) should be Brown (pin 34 at the PCM). Thanks to HISSIN50 for this tip.
Testing the system:
To test the computer, you can use a test light across the TAB or TAD wiring connectors and dump the codes. When you dump the codes, the computer does a self test that toggles every relay/actuator/solenoid on and off. When this happens, the test light will flicker.
Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve.
The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheel well turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the
vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
Typical resistance of the solenoid valves is in the range of 20-70 Ohms.
Theory of operation:
Catalytic converters consist of two different types of catalysts: Reduction and Oxidation.
The Reduction catalyst is the first converter in a 5.0 Mustang, and the Oxidation converter is the second converter. The Oxidation converter uses the extra air from the smog pump to burn the excess HC. Aftermarket converters that use the smog pump often combine both types of catalysts in one housing. Since all catalytic reactions depend on heat to happen, catalytic converters do not work as efficiently with long tube headers. The extra length of the long tubes reduces the heat available to operate the O2 sensors and the catalytic converters. That will cause emissions problems, and reduce the chances of passing an actual smog test.
Now for the Chemistry...
"The reduction catalyst is the first stage of the catalytic converter. It uses platinum and rhodium to help reduce the NOx emissions. When an NO or NO2 molecule contacts the catalyst, the catalyst rips the nitrogen atom out of the molecule and holds on to it, freeing the oxygen in the form of O2. The nitrogen atoms bond with other nitrogen atoms that are also stuck to the catalyst, forming N2. For example:
2NO => N2 + O2 or 2NO2 => N2 + 2O2
The oxidation catalyst is the second stage of the catalytic converter. It reduces the unburned hydrocarbons and carbon monoxide by burning (oxidizing) them over a platinum and palladium catalyst. This catalyst aids the reaction of the CO and hydrocarbons with the remaining oxygen in the exhaust gas. For example:
2CO + O2 => 2CO2
There are two main types of structures used in catalytic converters -- honeycomb and ceramic beads. Most cars today use a honeycomb structure." Quote courtesy of How Stuff Works (HowStuffWorks "Catalysts")
What happens when there is no extra air from the smog pump...
As engines age, the quality of tune decreases and wear causes them to burn oil. We have all seem cars that go down the road puffing blue or black smoke from the tailpipe. Oil consumption and poor tune increase the amount of HC the oxidation catalyst has to deal with. The excess HC that the converters cannot oxidize due to lack of extra air becomes a crusty coating inside the honeycomb structure. This effectively reduces the size of the honeycomb passageways and builds up thicker over time and mileage. Continuous usage under such conditions will cause the converter to fail and clog. The extra air provided by the Thermactor Air System (smog pump) is essential for the oxidation process. It oxidizes the added HC from oil consumption and poor tune and keeps the HC levels within acceptable limits.
Newer catalytic converters do not use the Thermactor Air System (smog pump) because they are designed to work with an improved computer system that runs leaner and cleaner
They add an extra set of O2 sensors after the catalytic converters to monitor the oxygen and HC levels. Using this additional information, the improved computer system monitors the health and efficiency of the catalytic converters. If the computer cannot compensate for the added load of emissions due to wear and poor tune, the catalytic converters will eventually fail and clog. The periodic checks (smog inspections) are supposed to help owners keep track of problems and get them repaired. Use them on an 86-95 Mustang and you will slowly kill them with the pollutants that they are not designed to deal with.
If your cats are not getting air pumped to them, the material inside will overheat and eventually melt, causing the cats to clog. You'll notice the car will run poorly and the mpg will suffer. If you have cats, you can simply cut the pipe off and replace it with a good piece of rubber fuel hose.
If you don't have cats, then that is why the pipe is most likely pinched off closed. I'd remove the entire pipe by removing the plug on the back of each cylinder head. You can use a 5/8" bolt or just reverse the plug bolts to each side of the head and block off the holes. You can also remove the TAD, TAB hoses, sensors, and even the smog pump and run a short belt.
Do you have the means to rehook the tube up?
Typically, 3/4" heater hose and two hose clamps works quite well.
That;s assuming the BBK pipe has a hookup for the smog hose
Revisiting topic- Cats aside, does plugging diverter valve hose that runs to cats affect how the diverter and TAD solenoid operate? In other words, when open, air flows to heads, when closed normally air flows down to cats. If hose to cats is plugged, where does air go? Can't go through valve and can't go out the bottom? I guess it could get pushed out the bottom of the bypass valve (first valve behind the smog pump).
If the air pipe to the cats is plugged, the air backs up like a bad toilet...
It has no place to go; that creates problems for the pump and plumbing.
That's what I figured. I got under the car and my BBK cats "did" have a place to connect the smog line. Looks like the previous owner cut the pipe and capped it. I'll get this fixed. Should be able to reverse what he did then put a piece of hose in to connect to the diverter valve.
In the short term, I see two possible options:
1. Remove plug at bottom of diverter valve- looks like a piece of metal tubing stuffed in the end of the rubber hose. Then I can just let the excess air blow out the bottom.
2. I have an extra bypass valve. I could swap out diverter valve with bypass valve (I would basically have two bypass valves). The bypass has blow off at bottom so might be a better option than having an open hose like in option 1.
In theory, both should work fine. I'm going after the fact the plugged diverter is causing code 46 since I have a new bypass and TAB.
Recommendations before I can get to the exhaust shop?
The metal tube that connects the diverter valve output check valve to the exhaust is $45-$50 at the auto parts store. It is made of metal due to the amount of heat that it gets exposed to. Think about that before replacing it with any kind of hose. The pipe connects to the H pipe right in the middle of the H that connects the two pipes together. That assures that both side of the cat H pipe get the air needed to make the catalytic converters function correctly.
Thanks. I'll do that. Didn't realize you could still get that pipe.
Thoughts on my interim options? Issue with letting bottom of diverter valve flow to atmosphere?
In theory it will work, in practice, it may not.
Having never tried it I can't say one way or the other.
Pulled cap off bottom of diverter valve, warmed up car and ran codes....what do you know, code free!!!!!! I'm pumped after chasing codes 41 and 91 for almost 3 years (weekends and when I had time) which lead to code 46 and now all clear!
I still plan to get diverter connected to Cats, but at least I can say my car should be running great (maybe a little noisy when that valve opens:) )
Thanks for all the help and feedback especially jrichker!
jrichker- I'll update the surging idle thread to share my story. I'm sure you didn't have "check to make sure the vac lines to the TAB and TAD are not reversed":)
I appreciate the follow up and input. It helps all of us.:)
Found a nice condition OEM smog tube that I'll put on within the next few weeks. Might be fun trying to figure out how to install this around my headers. That's most likely why the previous owner didn't install. Looks like I'll have to slightly modify it.
The diverter valve is loud when it dump air out the bottom which I figured would be the case- scared me when it happened during KOER test. I'm sure I won't hear if over my exhaust and radio. Thinking about it, I have no idea where that air was going with the bottom plugged (guess that's why I was throwing a code).
Checked codes again last night just to make sure it wasn't a fluke and still code free! I haven't driven the car yet, but did notice on a cold start the idle hovers around 1100-1200 for a half a minute then comes down. I would think that's normal, I just haven't observed the motor do that with all my lean and code problems. After a couple minutes idling smoothly, I did notice the RPMs started to climb like I was lighting pressing the accelerator. All the way up to 1500 and held at that mark (code reader off, but plugged into harness). I had to rev the engine a little to get it to come back down. Idle seemed to hold, but then would steadily climb, then drop. If you watched the tach, you'd think someone was doing it with their foot. I shut the car off and restarted. Ran perfectly after that with no more issues. I seem to recall the car doing this one other time before I unplugged the diverter valve and swapped out diverted valves.
I do need to put some miles on the car before doing anything else. Could be a fluke I guess. If this issues comes back, my next step will be to pull the TAB vac lines and plug them. My car never ran and idled so great after I did that a few weeks ago. If that cures the problem, then I guess back to chasing smog components....
Almost there, but still CODE FREE!
No codes and engine still runs great, with the exception of engine climbing to 1500 once randomly. Before it happened when I was idling in the driveway, this time it happened when I was driving. RMPs wouldn't come off from 1500. 1-2 mins of driving later, came back down and was fine.
Really odd and I'm not so sure this is going to be easy to track down without codes.
Still don't have the smog line on the cats. I'll probably play around with the vac lines to the bypass and diverter since I'm fairly sure it's related.
Been there and chased that rabbit...
The climbing RPM that goes away when you turn the ignition off is a TPS problem that requires replacement of the TPS sensor.
Thanks. My TPS is fairly new, but I have two others I can check to see if it changes things. It does come down on it's own. Very random and only seems to happen once each time I've taken it out (although I don't drive it long distances normally).
Raining here, but did let the car idle for 10-15 mins with vac line to bypass valve plugged. Ran perfect. Test drive later this week. If still occurring, I'll swap TPS's out.
what are your thoughts about adjusting TPS sensors by loosening and rotating slightly left/right? I've heard multiple Ford mechanics say these TPS sensors are not adjustable. I've always checked voltage anyway, just wondering what your thoughts are.
