C cjwillwin New Member May 9, 2011 20 0 0 May 15, 2011 #1 May 15, 2011 #1 My brake light comes on occasionally as I start driving fast, occasionally when pressing in the clutch, and occasionally when braking hard. Brakes look fine, fluid levels are good. Any ideas what the problem is?
mazen189 Member Jul 31, 2007 424 0 16 I.E. southern california May 18, 2011 #2 May 18, 2011 #2 master cylinder? maybe. Mine does that too.
C cjwillwin New Member May 9, 2011 20 0 0 May 18, 2011 #3 May 18, 2011 #3 I know that my old Taurs had a slow leak in the master cylinder, but it was a constant with that car. This one sort of comes on and off.
sneaky98gt 10 Year Member Apr 23, 2008 2,387 144 114 NC State University May 18, 2011 #4 May 18, 2011 #4 It's low on brake fluid. I've seen several Mustangs do that. When accelerating or braking hard, the fluid is sloshing around and the sensor is reading that it's low on fluid. Hence the light.
VOORHEES Stangnet's "35th Limited Edition" VIN Guy 15 Year Member Nov 9, 1999 3,046 36 119 LaGrange, GA May 19, 2011 #5 May 19, 2011 #5 Mine did that too last year, had a bad wheel brake caliper(stuck piston). You should check it out.
