Cel....trying To Check Codes. No Grey Plug?
First5.001
34
My CEL has been on since I got the car. Cleared codes, came back. Last night I went to check them, but there's no grey connector. Just the big one and the brown one. Everything I read said not to use that one...after I already tried it. I'm not sure if someone cut the other one, or what. I've checked CELs on Ford's before so I know what it looks like. Any suggestions?
Sent from my SM-G920V using Tapatalk
Brown one is hood light.
Follow the big one down to where it enters the harness. You may need to remove some tape or plastic retainer to expose the wiring. Do you find a broken wire down there somewhere?
What year is this car?
Should be the same as my '88 then.
Pretty much coming from same spot
Sent from my big ass iPhone 6 using Tapatalk
Do the simple stuff - unless you are color blind...
Check the wire color - the gray connector is connected to white/red wire - look for the wire...
Look for pin 48 on the computer wiring harness connector. This is where the white/red wire connects to the computer.
The following are diagrams courtesy of Tmoss & Stang&2birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
94-95 Mustang wiring diagrams
http://www.veryuseful.com/mustang/tech/engine/#95-95Diagrams
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
http://forums.stangnet.com/attachment.php?attachmentid=21328&d=1080916057
Use the ohmmeter function to make sure it goes back to pin 48 on the computer wiring harness. If it does, then jumper it to the black/white wire, turn the ignition to Run and the codes should dump.
The wire is more yellow/orange with a thin red tracer
Time. dirt and heat take their toll on wire colors in the engine compartment.
Find someone with a telephone line toner tool and connect the tone generator to pin 48 on the computer and then use the listener to trace the wire in the engine compartment.
See
View: https://www.youtube.com/watch?v=OyJsXpVZc5E
OR
View: https://www.youtube.com/watch?v=jP0AtN9hTP4
to learn how it works...
The first video uses a Harbor Freight http://www.harborfreight.com/cable-tracker-94181.html toner set - cost is ~$25.
There may be better quality or cheaper versions of this tool, but the best bet is to find a friend who has one of these tools and persuade him to help you.
As far as I'm aware it's stock to the car. The dirt and grease matches the rest of the engine bay. Again, pretty sure it's a factory 5.0/5 speed car. In the diagrams it's showing I can see a white wire with a red tracer. So that appears to be it, but there's no "dead end" where a plug would go. I have a power probe with the screw on wire piercing leads, I traced the white/red wire to the computer, but it doesn't appear to be in 48. I pierced it under the hood and linked it to the test lead in the plug. No luck.
Go back and find pin 48 using the diagram for the wire side of the computer wiring plug and see what color the wire is. Then chase that wire out to the self test connector area and see if it is there.
Reactions: First5.001
Ok. I have to figure out what way the computer plug and diagram are oriented so I know where it is. Almost looks like that spot in blank on my ecm.
I noticed even after having the battery disconnected for an hour the cel is still on the first start. Shouldn't it reset when the battery is disconnected?
It should, unless the fault is a major fault that the eec sees pretty much immediately
Gotcha. Really wish I could find the wire to check it. The only plug near it is the brown connector with the black/yellow wire. Did ford maybe use that one in 89? Anyway I can test the wire add not damage anything?
