Center Fog Light Grille...
This one looks like it is much better in quality than the one I purchased from Street Scene for almost $300. (discontinued?)
My grille is made from flimsy alluminum mesh. The weight of the fog lamps nearly causes it to sag.
And it is cheaply pop-riveted together.... some were even missing.:mad:
However, once installed and modified to stiffen it up a bit it looks GREAT!
I even modified it again to hold regular headlamps, so now I have quad hi/lo's.
I get lots of looks.
who has what, and how was the installation? my wife wants one on her 06...thanks in advance....
I had one on my 06 GT before I switched it back. It was from Street Scene and cost about 250 dollars. Looks OEM, it is lighter, and takes about 30 minutes to install. I also put on an running pony emblem from a 67 Mustang on the drivers side. I think it looks much better then the metal versions and is also very durable. I say go for it, I think you will be happy with it.
Heres a pic of mine before I changed it back.
I have the Street Scene Black Chrome model to match the lower grill I had purchased and installed earlier. I actually like it and think it is made better than the OEM piece. Easy to install once you get the bottom clips unhooked off the OEM piece. Just be careful not to scratch the top of the front bumper. While the lights were out, I replaced them with the fog Silverstars to match the Silverstar headlights.
^^ That one I don't think that Street Scene makes anymore, I haven't seen it in a while. I may be wrong though. The new one that they re-designed (they did that because the other one sucked as people already knew) has the same mesh as the stock grille.
I think if you look in their catalog they have a number of different options to choose from...plastic OEM style, Chrome, Black Chrome and Satin all with the center mounts and extensions.
