I took the ride in to get new tires put on today, no probs there but I talked to the "mechanic" at pep-boys and he said he thought I had some sort of problem with my clutch because the pedal seemed really stiff to him. I've got a centerforce dual friction so I expect it to be a bit stiff, but he said he's got the same clutch in his stang and his is much easier on the leg. Think this guy knows what he's talkin about? Should I check anything to be sure?
The clutch is only about 3yrs 25,000 miles old. It's seen a bit of a beating at the track but no power shifting or anything too extreme. Only reason I ask is cause I'd hate to be changing it again anytime real soon.
Update - I pulled the cable off and oiled it up real good with some WD-40/Lithium Grease. I'm glad I did it, The thing drives like a new car now. I think I may have also had the pedal adjusted up too high. I set it so that the pedal drops about 1/2" or so before engaging, I had it set to about 1/16" before. Now the pedal goes down like butter and I can actually feel the spring kicking the pedal back up when I let off. Still kinda nervous about not having the dust boot though.
