in order to get even the sohc motor to fit, you need to make enough room to fit a 460, and you cannot do that in a 65-66 mustang. you will have to change out the front suspension to a mustang ll and eliminate the shock towers. the next thing you need to tackle is the electronics, you can use the stock late model mustang wiring harness, but you will have to add everything the late model mustang came with, including the abs brakes, and the emission controls, etc. there are things you can eliminate, but you may end up getting a check engine light coming on, on a regular basis as the computer will be looking for certain responses from certain things. that means 4 O2 sensors in the proper locations. as for not using the 98 and earlier engines, bravo sierra. use them if you like, just swap on the newer pi heads and intake, or use the frt heads and intake. the best block to get is the 93-98 lincoln mark Vlll or the 96-98 cobra block(they will handle 1500hp out of the box). also if you plan on modding the engine get the book "how to build max performance 4.6 ford engines" by sean hyland. it is packed with excellent info you wont see anywhere else. he even give his recipe for building a 405hp(naturally aspirated!) cobra engine.
