  • SN95 4.6L Mustang Tech
Changing Plugs: need info!!!!
  • Thread starter Thread starter mattch2
  • Start date Start date Mar 17, 2004
M
mattch2
505
Niagara Falls
Mar 17, 2004
  • Mar 17, 2004
I plan omn changing my plugs in my 99GT.... Im goign to get the factory ford replacements so when i install them do they come set with the gap or do i have to do that?... im a newbie at the actualmechanical side of cars so any help and advice on how to change them would greatly be appreciated!!!
'96&'01Stang
798
Georgia
Mar 17, 2004
  • Mar 17, 2004
Even if they come already gapped I would take the time to check them.
M
mattch2
505
Niagara Falls
Mar 17, 2004
  • Mar 17, 2004
what si it that i need to gap them with??? can that be bought at any automotive parts place??? how much do they run?
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Mar 17, 2004
  • Mar 17, 2004
A feeler gauge or a little tool made specifically for plug gapping. They are cheap. $5 tops.
MT1083
1,033
Charlotte, NC
Mar 17, 2004
  • Mar 17, 2004
Do a search on spark plugs and you should come up with some detailed instructions.
satter_m
95
Akron, OH
Mar 17, 2004
  • Mar 17, 2004
Go to any Auto Zone or Napa and get these parts and tools (if you don't already have).
1. Spark Plug gap tool
2. Spark Plug wrench (if not that, then a swivel for your socket and a long and short extension)
3. Anti-seize for the spark plug boots
4. Spark plug grease
There are a couple of plugs that are a PITA to get to, so just be patient and take your time. My suggestion is to start with the driver's side plugs as they are the most accessible so you can get used to the process and how hard to pull on the boots. Oh yeah, you'll also need a screw driver to remove the boots. Do not overtighten the plugs. Once they feel tight, give them about 1/8 of a revolution with your wrench. No more or else you could strip them. Finally, always check the gaps to make sure they are up to the manufacturers recommendations. The only exception to this is if you get a set of Denso Iridium plugs as they come pre-gapped and are very easily broken with their tiny tips.
Hope this helps.
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
  • Gulftown980x
  • Jul 29, 2026
squeak93
S302 Saleen supercharger help
  • sschoup
  • Nov 19, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Nov 19, 2025
sschoup
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
