maverick0011 said:
I have a 2000 gt and it had headers, ported throttle body, flows, and cold air intake. I was wanting to know if there are any other cheap mods to give me some horsepower, im planning on getting pulleys within the next week. So please help me out, let me know about anything besides nos that can give me some hp.
A great deal of what "mods" you can chose is going to vary accordingly to your spending budget. I'll try to mention some simple mods that aren't too expensive( below 500 dollars).
Gears - Not a "power mod" but definately help out in acceleration and low end grunt. You can buy a set of gears for as low as 140 dollars if you do your shopping right. I'll include some links at the end of my post of places to check at for good deals of performance parts.
Under drive pullies - 199 dollars for the Steeda u/d pullies from
www.mustangtuning.com I don't know if these can be obtained for cheaper or not. It seems price of pullies has went up since I purchased my set nearly 4 years ago. Mustang Tuning also carries the March performance u/d pullies for about 60 dollars cheaper than the Steeda pullies, however, the March pullies are "piggy-back design" and usually don't make quite as much power as the Steeda u/d pullies. There are other companies that makes them as well. BBK makes a set of u/d pullies and can be purchased for 149.99 from
www.stangstore.com
Aftermarket Plenum - There are many choices here and thus, the price varies. The "best" in most peoples eyes is the Accufab piece, which runs about 220-240 dollars. The others are tend to be a bit cheaper. You can buy most of the other plenums for between 140-200 dollars. BBK, Grantelli, Trickflow, Dragon, and C&L all make aftermarket plenums as well. The Grantelli piece I believe is on sale for only 99 dollars at Jegs Automotive.
Porting and polishing the stock plenum - Free if you have the time and a dremel kit. This is a good alternative if you do not wish to buy an aftermarket plenum. I've been meaning to do a "how to" write up on this as I seem to be able to port and polish quite well. Just pick some rough dremel bits that are designed for buffing and grinding metal, port the inside of the plenum EVENLY, and then, use some different grits of sand paper or sand paper blocks to smooth it down. Start out with a coarse grit like a 40 or 50 grit, then a 100-120 grit, then a 150 gritt, then a 200 grit, and if you like a polished finish, use a 300-400 grit sanding sponge and clean up with some metal polish. This is very time consuming, but if you have the time and are willing to do it, its free hp.
Aftermarket mid-pipe - Since you already have headers and flowmasters, you need to get rid of that stock mid-pipe. At least, I'm assuming you still have the stock mid-pipe. Mid-pipes vary in pricing. Depends on if you get an off-road setup or one with hi-flow cats. A high flow catted mid-pipe will usually run between 350-450 dollars. An off-road setup will be cheaper, but won't pass on visual smog inspection. Typical cost for an off road pipe is 150-250 dollars. Again, depends on which company you go with an if you chose an x or h pipe.
Suspension - Although it does not increase power, suspension will increase ride handling and traction. Therefore, its as good as hp at the track. Some nice upper and lower control arms and sub-frame connectors would be a good place to start. Stick with the well known companies like Steeda, UPR, Holcomb Motorsports, Lakewood, Maximum motorsports, and Metco. Note, the last two are more expensive but if you can dig deep, I'de go with them as their reputations are second to none.
Sticky tires - Without traction, you might as well not be racing. You can buy a set of 2 drag radials for the rear for around 350 from most companies like Nitto, BFG, and Mickey Thompson. If you're looking to just race at the track, then get a spare set of 15 or 16in wheels for the rear and throw some drag slicks on them. Though it should be noted that the stickier the tire you run, the more stress it will put on the drive train and thus, the more likely you are to break an axle or rear diffential. You can avoid this by upgrading to a 31 splie rear-end setup, however, this will be a bit expensive.
Places I'de check for performance parts are the following:
www.stangstore.com
www.gefracing.com
www.modulardepot.com
www.partsshopper.com
www.coolblueperformance.com
www.jegs.com
Another good guy to deal with and I highly recommend is Randy Stinchcomb. He's a member both here and at Modular Depot. If you join up over at Moudular Depot, you can get in touch with Randy in the Ford parts section of their forums. He tends to have great deals on parts.
EDIT: I had to fix a couple of those links.
