Check Engine Light, Code 28?
  • Thread starter Thread starter 93tealstang
  • Start date Start date Jan 23, 2004
93tealstang
1,242
McSherrystown/Hanover Pennsylvania
Jan 23, 2004
  • Jan 23, 2004
My check engine light has recently started coming on and off. It starts usually as soon as the motor has reached full operating tempurature. I self checked for codes and came up with a code 28 which is "Vane Air Tempurature (VAT) sensor signal out of Self-Test Specification." Anyone know anything about this or where the sensor is located? Thanks for any help.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 23, 2004
  • Jan 23, 2004
There is no VAT on Mustangs, only on Mazda or MECS computer control systems. All the Mustangs use ECC-IV for the computer control system.
On MECS systems, the VAT performs the same function as the MAF does on ECC-IV systems.
The closest code to 28 (MECS) is 27 or 29 (ECC-IV). Here's the tech note for code 29...
Code 29 - Vehicle Speed Sensor (VSS) is an electronic sender mounted on the speedo pickup gear on the trans. It works the cruse control for both 5 speed and auto trans cars. On auto trans cars, it tells the computer to speed up the idle slightly as you slow down to a stop to keep the engine from stalling. Check to see if the electrical connector is plugged into it. Cost is under $30 and it is easy to replace.
Code 27 is the same sensor, slightly different problem symptoms.
93tealstang
1,242
Jan 23, 2004
  • Jan 23, 2004
Thanks alot!
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Crankshaft/Camshaft codes
  • rockinstang11
  • Oct 11, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 20, 2025
rockinstang11
