Clean or flush(Radiator) need some input.
ONZZ
238
Hawaii
I've got a 2000 GT and had never changed or cleaned the radiator fluid whatsoever. So do I use the Presotne radiator cleaner first, then the flush. not sure what to do? need some help.
i think flushing it after almost 5 years is a good idea. You wont believe what kind of junk builds up in there. I try and do it every couple of years and it runs noticibly cooler after the flush is performed. First warm your car up and than drain the coolant by removing the plug on the passenger side of the radiator. Than fill with tap water and the flush. You only need to get the car nice and hot and run it with the heater on for a few minutes than drain. However, i did this in the summer (no chance of freezing) so i left the water and flush in there for a week and it really cleaned the radiator well. Note: Running just water makes your car run cooler. Antifreeze does not make your car run cooler but actually hotter. It lowers the freezing AND boiling point of water. That is why it is called antfreeze instead of antioverheat. After flushed you will want to run some more water through the radiator to get out the excess stuff with the heater on again. Than fill with 50/50 water antifreeze. I used 60/40 water/antifreeze with a bottle of water wetter and my car runs noticibly cooler.
I'm at 37k miles and overdue for a flush too.
I've always drained just enough coolant to run the cleaner through all my old cars first and then drive around for a bit to loosen all the heavy garbage up, then drain it. Then I would make sure to keep draining/filling it untill all the cleaner is gone because it will cause foaming if you don't get it all out ... you don't want any foam or air bubbles in your cooling system.
I came across this pretty good article here when I was looking for a good flush procedure, check it out: http://www.bullittarchive.com/Maintenance/basics/flushing_radiator/
If you come across a better one let me know, I searched for a good, detailed one and that was the best I could do.
