according to the manual..it says u must cover the FUSE BOX, BATTERY, and AIR BOX (Air filter). I will do that , I will ALSO cover the ALTENATOR (just in case...) This will be my first time cleaning the engine (that has 31,000 miles on it) HOW do you guys go about doing this? do you just spray on engine degreaser, and then hose it off with the "garden Hose"? (Of coarse the engine will be cold when I clean it, as if it is hot the block could crack?)
I am so paranoid that the water will **** suttin up.....any tipz?
bad.
