You mentioned in another thread you were concerned about clearance with another intake you were thinking of running. Is it some custom intake you are building?
If not, just post what intake you want to run, and your clearance question, and someone here can probably tell you if it will fit.
Once I get back home I can check to see how much room I've got above the stock efi intake to determine if I've got enough room for my custom setup. It'l be kinda trick and I wanna be one of the first to have this.
There is a fair ammount of space between the stock intake and hood. I am running a Street Heat with a 1 inch spacer. All I had to do is cut the crossmember support on the hood on the driver side to keep it from rubbing the intake.
Kevin
I had to cut out part of my hood support also when I used to run a 1" spacer with my GT40 intake. I doubt you will even get 2" of clearance without changing your hood.
