clevland heads
  • Thread starter Thread starter webz1987
  • Start date Start date Feb 22, 2007
W
webz1987
  • Feb 22, 2007
I have been hearing some rumours lately that with some mods you can, bolt on a set of clevland heads what do you guys think?
Graydon5oh
215
ARKANSAS
Feb 22, 2007
  • Feb 22, 2007
never heard that but i knwo u can use windsor heads
W
webz1987
  • Feb 22, 2007
ya i've heard about that but i wasnt too sure about this one
Woodrow
183
Atlanta/Auburn
Feb 22, 2007
  • Feb 22, 2007
You can do it, you would want the aussie 2v or the 4v heads. It wouldnt be fun on the street though, in order to make power you have to turn it tight witht these heads and it seems most people dont have the balls to take it to 8500 or so. The would work well with a boosted setup though.
L
lang williams
567
cleveland, oh
Feb 22, 2007
  • Feb 22, 2007
From what i've heard, the cost of machine work to get them to work would buy you a nice set of aftermarket alum heads. but it would be different
W
webz1987
  • Feb 22, 2007
do you know of anybody that has done this? and if so do they like it?
Woodrow
183
Atlanta/Auburn
Feb 22, 2007
  • Feb 22, 2007
You have to have a set of custom pistons made to use them btw. I know several people that run combos like this. Most of the high dollar race motors have cleveland style heads on them. I wouldnt say this would be a good route for everyone as it requires alot more thinking then your typical windsor build, but if done right I am sure anyone would be pleased with the results.
W
webz1987
  • Feb 22, 2007
is it also worth gettin rid of polution control , and advancing your timing? heard good and bad about it
L
Lxstang306
33
  • Feb 22, 2007
351c heads will fit the 302w block and 351w ford racing some where in there book tells how to do it but u do have to change pistons valve are in the heads a diff way then the 302 heads. the old boss 302 was a 302w block with 351c heads also 351c heads on the winsor block u have to mod the intake to the port size also u have to drill holes in the heads so water can flow in them easy way to find every thing that has to be done its all in the ford racing not sure what page. and some of the 351c heads have big valve lot of 2.08 1.65 i found a set with 2.250 and 1.76 some have 2,19 1,65 http://www.panteraplace.com/Tech Info/Jones 2 4V2V heads.jpg
4v heads and 2v
JChalfan
551
Bellevue, WA
Feb 23, 2007
#10
  • Feb 23, 2007
  • #10
I've heard people talk about this before, and the general conclusion was that you're better off with a good set of aftermarket heads made for the 302. Cleveland heads can be bolted to a windsor block (302 or 351), but modern aftermarket heads are good enough to make it not worth the effort.
I'm sure people here with more experience with this will join in soon...
bentley429
Banned
Nov 25, 2004
528
Connecticut
Feb 23, 2007
#11
  • Feb 23, 2007
  • #11
Cleveland heads are some of the best flowing heads ford ever made. You would want either the 4v heads or the aussie heads like stated before. Can you just bolt them on? No, there is a pretty decent amount of machining and $$ involved. Thats basicly what a boss 302 is (302 with cleveland heads) which made good power for what it was. Depends on what your trying to do, if its a track car the heads can be sick on a high reving engine or with nitrous. A street car with heads that size on a 302 wouldnt make power until your up in the rpm which wouldnt really make to much fun for the street. Sounds like a nice set of alum heads or some World product heads would work well for you.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 23, 2007
#12
  • Feb 23, 2007
  • #12
If you can get Cleveland heads for $50-$75 a pair, it could be worth it. The last Ebay auction I saw, the heads started at $250 or so. That makes it much less attractive.
Do check out http://www.pricemotorsport.com/ if you have ant interest at all, t
The heads will need to have hardened valve seats installed to be used with unleaded fuel. That adds $275-$400 to the cost. Then you need adapters to mate your existing manifold to the Cleveland heads - see http://www.pricemotorsport.com/ for the adapters. The 2V adapters are $255, the 4v adapters are $267. If you use the 4V heads, you need a set of port stuffers to reduce the port volume in increase the flow velocity - that adds $112 plus maybe $150 worth of machine work to install the stuffers. Then you need to modify the heads and block to make the water passages line up. New push rods and gaskets are needed too.
Totals: ( I’m sure that I have missed some things)
2 V Heads
$75 heads
$350 machine work
$225 manifold adapters
$650
If you paid $350 for the heads, that works out to $1000, and a good set of used Trick Flows or AFRs could be had for that price
4V heads
$75 heads
$350 machine work valve seats
$267 manifold adapters
$112 port stuffers
$150 port stuffer machine work
$924
If you paid $350 for the heads, that works out to $1274, which is in the price range for a new set of AFR's
If you have to change the pistons, this isn't a bargain. If you can run the 2V heads and stock pistons (don't know if this is possible), it could be a cheap upgrade.
bentley429
Banned
Nov 25, 2004
528
Connecticut
Feb 23, 2007
#13
  • Feb 23, 2007
  • #13
2 V Heads
$75 heads
$350 machine work
$650
4V heads
$75 heads
$112 port stuffers
$924
Very true but the 4v heads arent going to be found for $75, and the 2v heads arent worth it. A decent set of 4v heads go for around $400 so it really isnt worth it for a street car.
Modular2v
3,222
23
99
oklahoma
Feb 23, 2007
#14
  • Feb 23, 2007
  • #14
you can do it but not worth the hassle since they now have more effecient heads that are direct bolt on...... like AFRs
Brett88lx
65
#15
  • Feb 23, 2007
  • #15
My buddy has a completely worked set of Australian Cleveland heads with over $1000 bucks in them. He went 12.0's all day long with a stock block and mild cam. With the right solid cam, he would have been doing low 11's easy. His cam really held him back. If you're interested, pm me.
thumper460
3,022
Orange Park , Fl
Mar 7, 2007
#16
  • Mar 7, 2007
  • #16
320 CFM intake runners.... they rock!! 302 crank.. 289 con rods.. BOSS 302 piston.. 7500 rpm all day!!
Just me..................................
Thumper
Modular2v
3,222
23
99
oklahoma
Mar 8, 2007
#17
  • Mar 8, 2007
  • #17
Thumper
i know a guy that is spinning his boss 302 to 11, 000rpm
D
DocZG
72
San Antonio, Texas
Mar 8, 2007
#18
  • Mar 8, 2007
  • #18
4v heads would be awesome on 408.....
Modular2v
3,222
23
99
oklahoma
Mar 8, 2007
#19
  • Mar 8, 2007
  • #19
i have a set
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
Salvage/rebuilt title question
  • djj62478
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 2, 2026
DadLife0724
