clevorness
  • Thread starter Thread starter Mr. Rustypwnz
  • Start date Start date May 26, 2007
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
May 26, 2007
  • May 26, 2007
Yo, I would like to build an engine this summer that is straight bad!! i would like to create a clevor engine! only thing i need to figure out is the intake, im gonna get some 351c heads, im porting them, valves, seals, springs and retainers. I would like to keep it efi so that it can go in my notch. Is there an intake that would work with these heads with efi, maybe a spyder?
Gimme sum ansurz!!!
jtfairlane
468
  • May 26, 2007
The only intakes I've ever seen for Clevor builds have been carbed. I'm not saying that EFI Clevor intakes don't exist, but it is such a rare and uncommon application I wouldn't be surprised if there wasn't one.
93 LX
3,081
Norwalk, CA.
May 27, 2007
  • May 27, 2007
I think the intake was call the Street Boss and yes it was carbed. No reason you could not use the that intake and weld in some EFI bungs. Good luck finding one and to tell the truth with all the new heads out there the reason people did this mod has all been eliminated.
Allen
91 HATCH
Banned
May 17, 2007
262
illinois
May 27, 2007
  • May 27, 2007
Gimme sum ansurz!!!
i would step it up more then it would be straight bad and you wont need to have the old iron cleveland heads
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 27, 2007
  • May 27, 2007
If you can get Cleveland heads for $50-$75 a pair, it could be worth it. The last Ebay auction I saw, the heads started at $250 or so. That makes it much less attractive.
Do check out http://www.pricemotorsport.com/ if you have any interest at all in Cleveland engines. They have adapter plates to mate an EFI intake manifold to Cleveland heads or Cleveland heads and block.
The heads will need to have hardened valve seats installed to be used with unleaded fuel. That adds $275-$400 to the cost. Then you need adapters to mate your EFI manifold to the Cleveland heads - see http://www.pricemotorsport.com/ for the manifold adapters. The 2V adapters are $255, the 4v adapters are $267. If you use the 4V heads, you need a set of port stuffers to reduce the port volume in increase the flow velocity - that adds $112 plus maybe $150 worth of machine work to install the stuffers. Then you need to modify the heads and block to make the water passages line up. New push rods and gaskets are needed too.
Totals: ( I’m sure that I have missed some things)
2 V Heads
$75 heads
$350 machine work
$225 manifold adapters
$650
If you paid $350 for the heads, that works out to $1000, and a good set of used Trick Flows or AFRs could be had for that price
4V heads
$75 heads
$350 machine work valve seats
$267 manifold adapters
$112 port stuffers
$150 port stuffer machine work
$924
If you paid $350 for the heads, that works out to $1274, which is in the price range for a new set of AFR's
If you have to change the pistons, this isn't a bargain. If you can run the 2V heads and stock pistons (don't know if this is possible), it could be a cheap upgrade.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
May 27, 2007
  • May 27, 2007
oh well, I was thinking something to be unique, for this notch, I can get some 351c heads and 400m heads for like 50bux so why not? I was thinking though, this car is going to be driven hard and I think a simple r block 306 high rev combo would be better off than this, this way I know it will work right, It would still be cool though..........
93 LX
3,081
Norwalk, CA.
May 27, 2007
  • May 27, 2007
Well check out the new BOSS 302 BLock instead if you want a hi-rev'r
91 HATCH
Banned
May 17, 2007
262
illinois
May 28, 2007
  • May 28, 2007
hi rev 331 with afr 185 and anderson cam will do it till 7200RPM
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
