  • SN95 4.6L Mustang Tech
Clunk sound.
  • Thread starter Thread starter scupking
  • Start date Start date Jul 18, 2006
scupking
1,186
Enfield, CT
Jul 18, 2006
  • Jul 18, 2006
This is starting to irritate me. I drove to an airshow a month a go and they made everyone park in a field. There was a big dip in the dirt road that was bigger then I thought and took it a little to fast and having 3 people in the car I bottomed out bad and heard a nice metal clunk sound. Ever since that day if I go over a small bump I will hear clunk clunk coming from what seems like the back passenger side. Sometimes I will hear a rattle other times it’s a clunk. It doesn't do it all the time so its tuff to figure out where it’s coming from. I try pushing down on the back of the car but don't hear the sound. IV looked underneath to see if my exhaust is tight and everything looks and seems good. I'm going to go back out tonight after my car cools down and have a look again. What do you guys think is making the rattling and clunking sounds?
FivePointStang
147
Springfield, OH
Jul 18, 2006
  • Jul 18, 2006
Sounds like maybe one of the welds came off somewhere on the mufflers. If you cant determine when you go back out, maybe take it to a muffler place and have them put it on a lift.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 18, 2006
  • Jul 18, 2006
I agree it could be a broken exhaust hanger.
G
GettinThere
553
Central Texas
Jul 18, 2006
  • Jul 18, 2006
If you can, jack up the back of your car and support it on jackstands under the frame (so the axle can hang). Then crawl under it and push up on the swaybar, causing the axle to move. I found a loose bolt that way, where the upper control arm attaches to the frame (torque box). That sound was more of a banging sound. Good luck.
Built98GT
211
OKC
Jul 18, 2006
  • Jul 18, 2006
I agree. You should put it on a lift and start tightening everthing up. It might be an exhaust hanger though like the others said.
scupking
1,186
Enfield, CT
Jul 18, 2006
  • Jul 18, 2006
Unfortunitaly I don't have away to lift the back up so I will bring it over to midas and see what they say.
Outlaw97GT
234
Redneckville, Tx
Jul 18, 2006
  • Jul 18, 2006
Check out your upper/lower control arm bushings also....just a thought.
If you dont have any jackstands, just pull half of your car on the curb. That will give you enough room to crawl under there and check it out yourself.
T
Torinalth
952
Clayton NC
Jul 18, 2006
  • Jul 18, 2006
i am chasing the same problem. i am thinking its either massive slop in the driveline, or i have something loose/broken on the UCA mounts. i am checking over everything this weekend with the back on ramps...
Torinalth
DTNODYA
831
  • Jul 19, 2006
FWIW, one time I went down a dirt road that had 'what looked to be small puddles of water' but I found out they were not so shallow. Long story short, one of my calipers came loose and was making a clunking noise so might as well check that too. Check tie rod/ends, bushings, exhaust hangers, etc...
StickShift84
82
Rhode Island
Jul 19, 2006
#10
  • Jul 19, 2006
  • #10
I am having the same problem. I actually checked under my car and pulled all the interior panels out of the rear of my car including the rear seat and I have not been able to find the noise yet, so if anybody finds what their noise is please let me know so I can check that. Torinalth, having a similar setup to mine do you experience a squeeking noise in the rear suspension when you force it up and down, it is another noise I am trying to figure out.
T
Torinalth
952
Clayton NC
Jul 19, 2006
#11
  • Jul 19, 2006
  • #11
not since the PHB and LCAs went on and the quad shocks came off... check your upper control arms, mountings, bolts, etc.... i am thinking its in there, and will post my findings about it this weekend some time,
Torinalth
StickShift84
82
Rhode Island
Jul 19, 2006
#12
  • Jul 19, 2006
  • #12
I was just looking under my car with a friend helping me this time and I found my upper control arm on the passenger side moving around when the suspension is moving, I am also in the process of removing my quad shocks, hope this is where my noises are coming from, thanks
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Sound deadener install
  • limp
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
limp
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
