Clutch Adjustment.....
  • Thread starter Thread starter Boss_Mustang_69
  • Start date Start date Oct 21, 2004
Boss_Mustang_69
34
BC, Canada
Oct 21, 2004
  • Oct 21, 2004
Well I have a stock clutch cable, and it engages/disengages way down on the floor on the pedal. Are adjustable clutch cables any good or are they a real pain?
omarECD
44
Philadelphia, PA
Oct 21, 2004
  • Oct 21, 2004
Don't get an adjustable cable, they break. Get an OEM Ford cable and adjsut it using an aftermarket quadrant and firewall adjuster.
Great guide here:
http://50stangs.com/techarticles/clutchcableadjustment.html
HISSIN50
34
129
Oct 21, 2004
  • Oct 21, 2004
the FRPP cable is reportedly good. one must install and align it properly (as with any cable).
if you have the stock quadrant, have you pulled up on the pedal to adjust it?
good luck.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 21, 2004
  • Oct 21, 2004
I have the Ford adjustable cable, seems just like the factory cable except it has and adjustment on the end. My original factory cable was streched, and almost seized.
Don't waste your time on just a cable, get a whole system, a PITA to install, yes but they are so much nicer. The factory POS is a a "self adjusting" unit which uses a plastic quadrant with an adjuster which uses teeth to hold it's position, on mine, the teeth on the last notch had worn off, combined with the streched worn out cable, I could hardly shift, near inpossible to go into reverse. I now have the MM quadrant and FWA and the FMS adjustable cable.
PNY PWR
522
Wichita, KS
Oct 22, 2004
  • Oct 22, 2004
I had that plastic quadrant break on my old 82 GT while I was in traffic, was very interesting w/o a clutch.
Q
qtrracer
39
  • Oct 22, 2004
On my '86, the pedal kept getting closer to the floor over time. Tried the stocker adjustment thing many times to no avail. Finally, had to replace the clutch so I did the whole quadrant, F/W adjuster R&R thing using Steeda pieces, with an OEM cable. Turns out that the stock quadrant's teeth had worn off, so it was totally useless for adjustment. As someone said, probably better to use an OEM cable with the aftermarket quadrant and F/W adjuster of your choice. Mine works great, although the R&R of the stocker is a PITA - worth every expletive though.
NCStang86
80
selma,nc
Oct 22, 2004
  • Oct 22, 2004
I've had a BBk quadrant and adjustable cable on my 86 GT for about 7 or 8 years and have never broken a cable and I drive it pretty hard.Ford cables are probably better quality but they aren't worth the extra $
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
