B BAHRAINI_STANG Member Jan 11, 2007 69 0 7 Aug 16, 2008 #1 Aug 16, 2008 #1 how to adjust it with firewall adjuster ?
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Aug 16, 2008 #2 Aug 16, 2008 #2 Turn the FWA CW to add slack to the cable. This moves the point of engagement closer to the floor. Turn the FWA CCW to remove slack. This moves the Point of engagement towards the top of the pedal.
B BAHRAINI_STANG Member Jan 11, 2007 69 0 7 Aug 17, 2008 #3 Aug 17, 2008 #3 i have summit firewall adjuster that theres a lock ring. i will try to adjust it ,do i need to remove the cable from the clutch fork. thanks for your reply
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Aug 17, 2008 #4 Aug 17, 2008 #4 If you remove the cable from the fork, it makes it tough to adjust and all but impossible to get back on the fork. Leave the cable in place. Loosen the lock-ring and adjust the FWA. Tighten lockring and test the clutch actuation in a safe location.
