UPDATE: I fixed it, by grinding 2/3 of an inch off the quadrant. Now it works great!
Hello,
I installed a Maximum Motorsports quadrant, and a Fiore firewall adjuster.
I am trying to install a Maximum Motorsports cable, the universal Ford OEM one, which is supposed to work with their quadrant.
I have the firewall adjuster screwed all the way in, so that the cable has maximum slack.
However, it looks like I'll have to pull the fork about an inch forward, in order to get the cable on the fork.
Is this normal?
It seems like, with the firewall adjuster all the way in, I shouldn't have to pull the fork forward, in order to get the cable onto it.
I believe that the Fiore firewall adjuster is slightly thicker than the Maximum Motorsports firewall adjuster, but only a few millimeters at most, I think.
The reason I ask, is that I'm having a hard time bending the fork forward enough, because it's hard to get a crowbar at the correct angle. Also, it seems like the cable will be too tight, even if I do finally get it onto the fork.
I believe that I have the cable routed correctly.
I'm wondering if the cable is too short. Could it be a manufacturing defect? Or maybe something weird about my car? My car is pretty much bone stock.
Hello,
Is this normal?
