My clutch cable snapped in 2018 so I put a new Ford racing adjustable cable on it then.
Things have been fine until this year I've noticed it starts burning occassionally. It happens sporadically amd I can't really pinpoint a specific reason it's happening. But i only smell it after shifting and then it goes away. I don't ride the clutch and im pretty easy on the car and again, I have not smelled it until this year. There is no slipping either.
I don't drive the car much, just a few times a month in nicer weather.
So, I checked out the cable at the bell housing ( no firewall adjuster) and it seems tight but I tightened it down a little more.
I test drove it after tightening it and im not smelling anything but I only drove around the block.
My question is do u think my cable just stretched some over the past 5-6 years and just needed to be tightened? Would a loose cable cause me to burn the clutch?
I've read all about clutch tightness and preload but not sure how to determine for sure I have the proper tension. The cable is tight with no slack but not sure of it the 4-15 lbs of preload.
What do u think?
Thanks!
What do u think?
Thanks!
