Clutch/flywheel re-install. Two questions.
Scot_94GT
262
Spring Lake Park, MN
1) What am I supposed to put on the flywheel to crank bolts to prevent oil from leaking through. My Haynes manual says to use a "teflon thread sealer". The Chilton's book for my Neon says to use a "Locktite thread locker or equivalent". I have heard people on this baord say to use RTV...but isn't RTV a gasket compund, not a thread locker/sealer? Anyways...If you HAVE used RTV and it worked, is this the stuff?
If not, what is the correct stuff, and if possible post a pic of the container, so I don't have to guess when I am in the parts store.
2)What type of grease do I use on the throwout bearing and clutch fork ball joint? In the Haynes manual is just says use "high temperature grease". I have heard people on here using marine grease. Is this the marine grease?
Also, do I need to grease the piolt bearing with this stuff?
That RTV will do just fine...
Any hi-temp grease would do....the dif between marine and auto??? can't answer that one....maybe it water-proof to... :D Any parts store can set you up with right stuff..
No need to grease the pilot shaft bearing...Its a sealed unit...you cant get grease in there anyway....throwing abit on the I.D. of the bearing where the tailshaft of the tranny goes in should be done though...you dont want metal to metal there.... or a light coat on the tailshaft before you put the tranny in...Either will suffice...
Scot_94GT said:
Both parts stores I went to looked at me like I had a third eyeball when I mentioned marine grease, and RTV to them for my application.
Well to begin with I would only go to a marina and asked for that type of grease...Auto parts guys prooly would go W.T.F.??? You should be able to get a small container of hi-temp axle/bearing grease no sweat...
If you asked them for flywheel bolt sealer or something along those lines, thats prolly why you got the 3rd eye...there is no such item so to say.... :D
That RTV you posted should also be hanging on a shelf with all other types of RTV, very common item...You could go to Walmart and get both those items not sweat and not get the 3rd eye routine... :D ...
The factory uses a thread sealer (orange) when they assemble....You can reassy with RTV simply to seal the thread from possible oil leaking thru...it wont harden like the factory stuff, but will cover you for possible leakage...That factory stuff hardens like freakin concrete anyway...its more of a Loc-Tite/thread sealer combo...
Hope that helps you some....Welcome to the game....
So if I just use RTV, the bolts won't work themselves loose over time since the RTV does not harden to lock the threads?
dcarlson said:
I've always used red locktite and never had a problem with oil leaking through.
The most important thing to keep them from backing out is to make sure they are all torqued properly.
:stupid: RTV is not an equivalent to threadlocker. I've never used anything but the the red loctite (271/272) and I also have never had any oil seep out around the bolts.
I'm not sure RIO, but I think you meant the TOB is sealed. The pilot is an open center roller bearing :nice:
:flag:
Wheel bearing grease for the TOB and release lever. You want an excess amount where the TOB would meet the pressure plate fingers. In case you spin the bearing later, it won't squeak and squeel later.
Autozone sells "thread sealer" in little tubes. They are white with red letters. The stuff stinks, and really gets annoying when you get it on your hands. You will smell it for a couple days :doh:
You are also supposed to put white lithium grease on the pilot bearing if you replace it. Might as well since you are here and doing it. Follow the haynes manual and take your time.
Scott
Well..I today I bought some red RTV, and a torque wrench, so hopefully the bolt will never back out.
When I was in walmart getting some ATF for the tranny, I also bought a tube of "multi-composition high temp grease". It was in the automotive section next to the other tubes of grease. The manual just says "high temp grease" so I'm assuming this will be ok.
OT:
Do I need to have a shop balance my flywheel with the new pressure plate on it? There is a shop around here that will machine the contact surface down for like $35, so I assume they would be able to balance the assembly also. Do I really need them to turn down the flywheel? There are no grooves or anything in it.
I agree there's a dif between RTV and thread sealer...no doubt...I didnt wanna confuse the issue as he brought up the RTV....
The old flywheel should be turned for a new clutch as its glazed over..you want a fresh surface for the new clutch to mate to...balancing it with the pressure plate??? Never heard of that one...Turning the flywheel will suffice...The pressure plate is postioned with 3 dowels so that would "true" it up to the flywheel...makes sure you dont lose those dowel pins....knock them out from the other side and hang onto them...gotta have em at re-assy time...
I bought my TOB and PSB at Napa...both were sealed bearings...
You mean to tell me that the center of that PSB is smooth and you can't see/feel the needle rollers with your little finger or a scribe??? That's interesting. I'm gonna have to look into getting one of those. I think you're at an advantage, in most cases, if you can use a sealed bearing VS non-sealed. Thanks for the pic :nice:
Here is some part numbers of common pieces needed for a clutch install on the 86-95 5.0L’s:
ARP Flywheel Bolts - ARP-100-2801
ARP Starter Bolt Kit - ARP-450-3501
ARP Thread Sealer - ARP-100-9904
Ford Pressure Plate Bolts and Flywheel Dowel Pin Set - 397-M-6397-A302
Stock Replacement Flywheel - 397-M-6375-B302
Heavy Duty Ford Racing Clutch Kit- #M7560A302
King Cobra Ford Racing Clutch Kit - #M7560C302
Ford Racing 79-95 Aluminum Driveshaft - FMS-M4602G
www.buyfordracing.com sells an OEM cable and clutch fork for $40 – 7553-A302
www.50resto.com or your local parts store carries your throwout bearing, pilot bearing, and rear main seal.
www.steeda.com has a chart of what correct speedo gear you will need for your application.
Transmission fluid – Dexron/Mercron III ATF fluid for the T5
Disclaimer – Do at your own risk and research.
First jack up the car safely and securely on all four corners and the more room underneath the better so you can remove and install items much easier. Proper jack and jack stand placement is key for safety. A friend or two is probably the best way to go about the install. You will find yourself needing more hands than you have pretty quickly.
Go ahead and disconnect the negative side of the battery. Go ahead and remove the shifter (or atleast the handle) so you can drop the transmission without the shifter holding it in due to rubbing. Four bolts hold it to the transmission and two bolts hold the shift lever on the shifter base. Pull up on the shifter using the handle if you choose to remove it completely. It will give you better leverage but be careful when it finally pops loose because you might go flying back or scratch interior pieces with the shifter. I put towels around the console to prevent this. Next I would go under the car and start unbolting your mid-pipe, which is held on by a total of 8 bolts (2 for each point of connection). They can be a pain to remove if they haven’t been removed in a while they can seize to the studs/bolts. Use some wd40 or Liquid Wrench to help with this process. A combination of extensions and a swivel would be a good start to getting to the manifold/h-pipe connections. Make sure before you completely drop the pipe that the 02 sensors are disconnected. You can use a flathead screwdriver to pop off the harness connection. Pull the mid-pipe from underneath the car. Now would be a good time to clean it off from all the road grime. Next I go to remove the driveshaft which is held in by 4 bolts in where you will need a 12 point 12 mm socket or wrench to fit over the bolts perfectly. The driveshaft bolts are commonly very stubborn to get off. If you can get a break-over bar on the bolts then you should be able to break them loose. I use the appropriate wrench and put a hollow bar over it and break them loose that way. It helps on the leverage. When you go to remove the bolts you will need to rotate the driveshaft to get an angle on the bolts. When you find the right angle put the car in gear (take your shifter and temporarily pop on the tranny and stick it in gear) and put on the e-brake to prevent the back tires from turning so you can break the bolts loose. Once you have removed all 4 bolts you are now ready to remove the driveshaft. When you pull the driveshaft out from it’s trans housing do not be surprised if transmission fluid comes out (normal). You can buy the driveshaft “plugs” that will be placed where the driveshaft was inputted or you can use a rubber band and ziploc baggy and rig it up to catch any of the fluid so you don’t loose to much.
Now that the driveshaft is removed you can go ahead and undo any tranny connections that are on the transmission. You need to remove the neutral safety switch (pulls off) and speedo gear (held on by one bolt). Pull them out of the way so they don’t snag on anything. Remove any other connections that you may notice like the clutch cable which is held onto the clutch fork and also held on by a clip (do not loose it). I then start to undo the transmission bellhousing bolts (I remove the tranny with the bellhousing attached). Most of them are 5/8’s bolts with a couple smaller ones near the bottom. Make sure you loosen all the bolts because some go up near the lower intake of the engine and can be accessed thru the engine bay or if you have smaller hands (that I’m not blessed with) you can reach them from the bottom. Your transmission crossmember and bellhousing alignment dowel pins are holding the transmission right now. I next remove the starter, which is held on by 2 bolts, and I don’t undo the connections and just ziptie underneath the car and out of the way. I would go ahead and start bringing a good jack underneath the car accompanied with your buddy to get ready to remove the transmission. Two bottom bolts hold it on and two studs go through the side mounted to the body of the car. Remove all 4 of these with the jack properly supporting the transmission while your doing this. Make sure the jack sits flush and has a good balancer on it to accompany the bulkiness of the transmission. With all the bolts and connections undone you can go ahead and start pulling on the tranny towards the rear of the car as to release the input shaft from the pilot bearing and clutch assembly while also letting the bellhousing coming off the dowel pins. Make sure the engine is supported because it doesn’t have the transmission’s weight to counter the tilt. Another jack would be nice. Put a board to even out the weight distribution over the oil pan. Once the input shaft is clear of the clutch assembly (as not to get damaged) and you have wiggled it loose go ahead and drop the transmission slowly while not tilting it so you don’t loose transmission fluid through the speedo gear hole. Remove the transmission out of the way of the bottom of the car. It would be a good time to clean the transmission, crossmember, and driveshaft at this point. Use some degreaser and some “elbow grease” at your local car wash to help you out. You can clean up the bottom end of the car the same way. Good time to do it right? Check your input shaft bearing retainer and shaft itself for scouring or any other kind of damage. It is a good idea to replace all your clutch assembly parts together. Now you can go ahead and remove your pressure plate/clutch disc. If you want to reuse the pressure plate and disc for some reason. Back the 6 pressure plate bolts off evenly as not to warp the plate or disc. When you loosen it watch out because it is heavier than one would think so be ready to catch it or have your friend hold on to it. Once removed you can check the disc and pressure plate for problems and wear to see what is going on with your car. You can now see the flywheel that is held on by 6 bolts as well. These bolts are on pretty tight and I personally use an impact wrench to remove the bolts. I do them evenly as well to prevent any kind of warping. The flywheel weighs 21 lbs so be ready to catch it as well. Remove the flexplate (goes between bellhousing and block). Once the flywheel is removed and out of the way inspect the teeth on it and condition of the clutch disc mating surface. You may need a new teeth ring gear or you may not. You will want to have your flywheel resurfaced (turned) at your local machine shop. They can charge anywhere from $25-$40 bucks for the resurfacing. It will provide for a nice smooth (unspotted) fresh surface for your new disc and pressure plate to work with. Well worth the money if you consider the negatives of not doing it. Since the flywheel is removed you can now see the rear main seal and pilot bearing. If the rear main seal is not leaking DO NOT touch it because it is doing it’s job. A rear main seal install can be tricky. If you see you need to remove it (leaking) you can use a flathead screwdriver to pinch the seal and remove it. You can use a slide hammer as well. You DO NOT want to scratch the crankshaft at all when removing the seal. If you do you will need to put on a sleeve to prevent it from leaking. So be very careful on the crankshaft end. Some have put a screwdriver on the block side of the seal and pryed it out CAREFULLY to remove it. Once removed (in which ever method you chose) clean up the crankshaft and block area where the seal goes into it and put some oil in there to help the seal to go in smoother. I would go ahead and clean the back of your heads and block while your at it. Simple Green and some nice clean smooth rags will be suffice. To install the new rear main seal you want to take your time with this. Put some oil on the inside ring of the seal where it rides on the crankshaft itself. Install the rear main seal EVENLY. You can use the old rear main seal to tap against it to put the seal in the housing. Tap it in a circle slightly and put it flush with the block. Don’t bottom out the seal. Some like to put silicone on the outside ring of the seal (where it meets the block) – it acts like a bridge to keep the oil away. Don’t put any high-temp silicone on the seal part where it meets the crankshaft because it needs to turn, not like it would stop it from turning.
I would go ahead and inspect the pilot bearing by rubbing your “clean” finger in the hole to see if you feel any scouring or rough edges that could effect the ability for your input shaft to function properly and smoothly. If it seems smooth and visually looks good I would go ahead and keep it in there. If your one of those people that are a “miswell while I’m down here” type person then go ahead and change it out. Put some grease in the pilot bearing hole and get a brass punch the same diameter of the hole. You then stick the punch in the hole and hammer the punch into the grease to remove the bearing hydraulically. The bearing will push out as you use the grease as a displacement. You may need to add grease a couple times as more surface area is revealed and it will eventually come out. You may also use a slide hammer on the pilot bearing as well. Most pilot bearings are pre-greased from the factory but I put some bearing grease (just a bit more) on the inside/outside to help with lubrication. Take the bearing (after taking notice of how the pilot bearing was in previously and install it the same direction). Tap it in a circular motion evenly so it doesn’t become offset. Make it flush with the block as well I believe. You are now ready to reinstall the flywheel. Take the new or used (but resurfaced) flywheel and rotate it so the bolt holes (they are offset) match with the flywheel holes and put in a couple bolts to hold the flywheel up there. Before doing this though I would clean up the crankshaft threads a bit of any oil. Just as well MAKE SURE you clean all the clutch assembly parts well before installing them with some carb or brake cleaner to take off human grease and rust inhibitors. Anyways, once the flywheel is held up there go ahead and get some loc-tite and apply them on the threads of the flywheel bolts. That is all I have needed and I have go no oil leak. Some use thread sealer for extra security from leaks. Use it at your own reasoning. Put all the bolts in with some loc-tite and go ahead and start tightening them in a “star” pattern (evenly). The flywheel bolts need to be torqued to 90ft. lbs using a torque wrench. Make sure you clean off the flywheel of any oil or grease from your hands so it doesn’t effect clutch performance and grab. Next you can go ahead and get your clutch disc ready and I’m hoping you got a clutch alignment tool (10 spline – 1/16th input shaft size) and make sure the clutch disc is facing the correct way. Most will be labeled either ENGINE SIDE or FLYWHEEL SIDE. Put the alignment tool in the clutch disc and stab it into the pilot bearing. It may support itself. Get your buddy to hold the input shaft as evenly as he can while you take the pressure plate and set it on the flywheel alignment dowel pins (you need those alignment dowel pins to align and balance the pressure plate properly). The pressure plate will sit on the pins and hold itself. Now get your 6 pressure plate bolts and start threading them in. Go ahead and tighten the pressure plate bolts in a star pattern (evenly and go thru it a few times so you don’t warp the plate). While it is being tightened have your friend have the clutch alignment tool centered for best performance. Torque the pressure plate bolts to 24 ft. lbs (most clutch manufacturer’s recommend that). It probably wouldn’t hurt to put a bit of loc-tite on those bolts but it isn’t completely necessary. You know have the clutch assembly put together. Remove the clutch alignment tool.
Go back to your transmission and check your throwout bearing (TOB) for wear but I would suggest replacing it anyways because it is fairly cheap. Pay attention to how the old one is installed on your retainer shaft. Remove it off the clips and install the new one and check to see if it rides smoothly and turns. You can do this by moving the clutch fork (natural movement) up and down the shaft. Put some high-temp grease on the throwout bearing where it mates against the pressure plate forks. A tip: The “fat-end” of the throwout bearing goes against the pressure plate teeth. You are now ready to install the transmission. Put it on the jack for support and get your buddy to help you jack it up there. Keep in mind that the input shaft on your transmission has to slide in smoothly into the input shaft (the job of the clutch alignment tool). You may need to spin the input shaft so it will “spline” into the disc. As you are getting the spline to line up you need to make sure the bellhousing alignment dowel pins are still in place and that the bellhousing slides over them which will help align everything properly. Go ahead and install the bellhousing and transmission bolts and tighten them up. Now to go back to the transmission install. If it doesn’t “pop” in you need to check for any clearance issues or objects in the way. You should not have to “pull” the transmission on with any bolts…so be mindful of that. Tighten all the bolts down tight so they won’t come loose. Start reconnecting the clutch cable with the clip and onto the clutch fork. Reinstall the speedo gear (a good time to replace it by the way if it is all chewed up) and the neutral safety switch. It would be a good idea to go ahead and put on the crossmember to hold up the transmission and then remove the jack from underneath the car. You may now get ready to install your driveshaft. Pull your fluid plug or ziploc bag away and slide the driveshaft splines into the transmission and start threading in the driveshaft bolts. Put loc-tite on them because you definitely don’t want them bolts to come loose. Torque them down to 100 ft. lbs. Go ahead and put on the mid-pipe and check for any kind of wires or connections that might melt on the exhaust pipes. Fix it (zipties work wonders). Plug in your 02 sensors. Do a quick visual check underneath the car for anything loose or not needed. Go inside your car and reinstall your shifter. Clean the shifter mounting area with a gasket scraper of the old silicone or gasket being careful not to get any in your tranny. Lay down a bead of high-temp silicone around the mounting area and bolt the shifter down (4 bolts) and reinstall the shifter lever/cover/and knob after your sure you got the stop bolts and shifter shifting properly. Just as well make sure the cover is installed around the shifter to keep dirt out of your interior and road noise down. Finally reconnect the battery and clean-up.
The install is now done but when aftermarket pieces are applied you will need to adjust where the clutch engages and disengages to your liking. There are aftermarket pieces like clutch cable firewall adjusters, adjustable clutch cables (you adjust at the clutch fork), and aftermarket quadrants from maximum motorsports, UPR, Steeda, etc. If you use a firewall clutch cable adjuster you can turn it counterclockwise and make the clutch pedal grab closer to the floor. If you turn it counterclockwise it will raise the pedal grab higher up. Replacing the stock plastic quadrant is a good idea and can soften up your pedal as well with the feel. I have seen and learned from personal experience that an OEM non-adjustable cable with a firewall adjuster is a great combo to have and keeps the pedal feel softer than what it could be.
Follow proper break-in procedure by being easy on the car for the first 400-500 miles to properly seat everything.
Good Luck:nice:
Thank you:nice: I have a h/c/i write-up as well with a very similar setup (it is longer). Feel free to add other part numbers that would be good to know or have or any other tips or info...
nice write up...I'll be referring to it for reinstall. :nice:
Question about the rear main seal:
Your write up says to intall the rear main flush with the block. Well...I did mine before I read this and mine is in about a 1/16" (or maybe a little less) deeper than flush....about even with the inside of the chamfer on the block. Should I not worry about it? I'm pretty sure I didn't bottom it out though (although I'm not sure how far in I would have to push it to bottom it out).
Also, how important is it to get the seal EXACTLY sqaure in there? I mean, should I measure the depth of it with a mircometer all around the perimeer of it, or is just eyeballing it feling it with my finger good enough?
You'll be fine with the deepness of your rear main seal. I believe there has to be .005 thousandths or something like that clearance on the rear main seal which is something you can't really measure. Pushing it "past" the block face shouldn't be a problem at all...
Getting it square as visually possible is pretty crucial. I didn't tap mine in to evenly and it leaked at the inner seal because it kinked a bit.
Wait till some rear main seal experts chime in here:)
Since stories are always better with pictures...
Got the tranny out.
Bellhousing, clutch and flywheel are gone...time to change the rear main seal.
Parts are piling up.
Yanked the headers.
Old restrictive stock headers in their new home.
Me and my new toy. (Husky Pro torque wrench)
Ok..good. I was afraid I may have to pull it out, and likely replace it with a new one (since pulling the original required me to drill a hole in it screw in a self tapping screw, and use a vice-grips to yank it out.
I suppose, being the anal-retentive perfectionist that I am, I will have to go measure the depth of it with the a** end of my micrometer all around it.
I bet you don't have anything to worry about. As long as you see a seal you should be fine. If your a perfectionist I bet you done got it. I'm just giving you the ideal situations of putting in flush (or there about) and tapping it in evenly as possible to be ideal.
I'm sure your fine :nice: My leak may have came when I was initially sliding it on the crank by just trying to get it started. Next time I will take my time instead of doing it when I wanted to go to bed :p
