  • 1994 - 1995 Specific Tech
Clutch help--which adjustment setup?
  • Thread starter Thread starter Blackened302
  • Start date Start date Nov 30, 2005
Blackened302
1,439
South TX
Nov 30, 2005
  • Nov 30, 2005
my TOB is going bad--i have that annoying whine and it looks torn up. i got the steeda firewall adjuster but i can't use it because steeda says i need their quadrant (i've already tried and it didn't work, didn't give me enough slack so i guess i do need their quadrant).
i'm gonna replace the tob and was wondering which you guys recommend and how much $ it costs. i'm guessing you're gonna say get one from FORD.
i also want to get an aftermarket quadrant so i can have as much adjustability as possible. should i just get teh steeda one to go w/ the firewall adjuster, or what? the cable looks good, so i'm not going to replace that. what set-up are you guys runnig and how is it working out? i'm looking to spend under $100.
thanks for the help, guys.
HISSIN50
34
129
Nov 30, 2005
  • Nov 30, 2005
I am confused. If you have a stock quadrant, you can use that to make the adjustment. Or if you have an adjustable (at the fork) cable, you can adjust it there too).
FWIW, I went with an oem cable, single hook quad and Extreme FWA on the fox and it performs very nice. I spent 100 beans, but the SN95 cable is a little more (MM might have as good a deal as anyone. I did not research it for SN's).
If your Steeda FWA is all that is holding you up otherwise, I would sell it and get a different FWA that works with your combo. I missed what components you run now to try and make suggestions.
Good luck.
HISSIN50
34
129
Nov 30, 2005
  • Nov 30, 2005
And yeah, agreed. Ford TOB.
Cobra4075
286
Tinley Park, IL
Nov 30, 2005
  • Nov 30, 2005
I have steeda setup on my car. It's a nice piece and I believe you can buy the individual pieces. The only complaint is about 5,000 miles after install, the cable would pop off the quadrant when you took your foot off the clutch. I used some tape to solve my problem. Steeda now sells a clutch pedal stop to eliminate this problem.
Blackened302
1,439
South TX
Nov 30, 2005
  • Nov 30, 2005
Good luck.
sorry, i know my post might have been a little ambiguous.
right now my set-up is completely stock. the only aftermarket piece i have is the steeda firewall adjuster that i need to get a quadrant for in order to make it work.
i am going to get an aftermarket quadrant and a ford tob, and i'm curious as to what adjustment set-up you guys are using. sorry for the confusion and thanks for the help. keep 'em coming.
Blackened302
1,439
South TX
Nov 30, 2005
  • Nov 30, 2005
do you have the double-hook quadrant?
HISSIN50
34
129
Nov 30, 2005
  • Nov 30, 2005
Thanks for the clarification. If it were me, for nice componentry, I would get Fiore's stuff (if it works for SN95's). The FWA is very trick. See Jeremy Thompson's full review for more info (installed on his 4 eyed fox).
If on the cheap, go the route I did and use the UPR triple hook quad, OEM cable (if needed - it is worth the extra cost. I think MM sells them for 60-70 bucks), and FWA of your choice. You might check with Danny - I think he was going to install similar components a little while back. I am not sure if him having his car under water hindered that project though.
As an aside, did you release the quadrant and pawl before you tried to hook up the cable (with the new FWA installed)? Otherwise, the quad would be adjusted for not having the FWA and might be a little tight.
I have a bud who uses a UPR FWA on a stock quad (on a fox) and it works real nice for him. I have not seen a Steeda FWA, but I cant imagine it is hugely different than other FWA's out there. I just had to ask in case it helps for now.
Good luck.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 30, 2005
  • Nov 30, 2005
OEM cable, steeda quick release quad. , and UPR firewall adjuster
Blackened302
1,439
South TX
Dec 1, 2005
  • Dec 1, 2005
hissin:
i adjusted the clutch after installing the steeda FWA (by pulling up on the cable until it *clicks, then pushing the pedal all the way down a couple times) and the clutch fork wasn't going back all the way--guess i need about a half-inch more slack. since steeda says you need their quadrant in order to use their FWA, i figured that's why it wasn't working. my bro-in-law (who's a mustang guy and has messed with and taken apart MANY) couldn't figure it out, either. hope that helps your diagnosis.
HISSIN50
34
129
Dec 1, 2005
#10
  • Dec 1, 2005
  • #10
Paul, I cant think of anything else to offer. I have not used the Steeda FWA before, so I dont know what is going on.
I can say that I encountered a similar issue when using my SVO single hook quadrant on the fox. The SVO quad only came with the Ford adjustable cable, and would not work with my new OEM non-adjustable cable. The SVO quad was about twice as long as the UPR single hook I installed to replace it, and I could not install the new cable onto that old quad (it would have required me to pry on the fork to get the cable on - not good).
That is neither here nor there - just sympathizing since it sounds like we went through similar issues but with different components.
As others suggested (I think), I have read that the Steeda cable is needed for some Steeda components, but that is just a recollection from threads some time back. It rang a bell though.
If you want to read some review and stuff, check out Jeremy Thompson's article (note that it is written about his 4 eyed fox, but much of the info is ubiquitous):
http://www.50stangs.com/techarticles/clutchcableadjustment.html#Which clutch cable should I use
Good luck Paul.
Blackened302
1,439
South TX
Dec 1, 2005
#11
  • Dec 1, 2005
  • #11
thanks, man. yeah, i understand what you mean--i would've had to mess w/ the clutch fork so i decided to not use the FWA until i get the quadrant.
there's a good bit of info in that article, thanks for the link. i'll have to read it when i have more time--it's bedtime (4:11 am). thanks for the help, i appreciate it.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Dec 1, 2005
#12
  • Dec 1, 2005
  • #12
i had the steeda quadrant and firewall adjuster. just recently switched to the fiore performance setup. there is no comparison between the two. i would recommend the fiore setup all the way. and as was said above, an oem throwout bearing will work fine. while you are in there, make sure the bearing retainer is in good shape otherwise you may find yourself having problems again.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Dec 1, 2005
#13
  • Dec 1, 2005
  • #13
Green and I just installed the newly designed FIORE stuff on my car. Looks to be top notch.
Blackened302
1,439
South TX
Dec 1, 2005
#14
  • Dec 1, 2005
  • #14
how much is this fiore stuff?
VibrantRedGT
424
154
Boca Raton, Florida
Dec 1, 2005
#15
  • Dec 1, 2005
  • #15
http://www.fioreperformanceparts.com/index.html
legalize420
1,541
South Florida
Dec 2, 2005
#16
  • Dec 2, 2005
  • #16
the steeda fwa should work with the stock quad. it is the same as my summit one with the exception of having a little allen head screw to hold the adjustment. i got the steeda quad and steeda fwa but never installed the steeda fwa because i already had the summit one in there. i would try adjusting the fwa all the way towards the firewall then hook the cable up to the quad. then you should be able to bring the fwa away from the firewall and it should take up the slack. you did remove the plastic piece from the stock cable right?
Blackened302
1,439
South TX
Dec 2, 2005
#17
  • Dec 2, 2005
  • #17
yeah, tried it with it removed and with it on. we spent about 4 hours trying different configs with no avail. i noticed that when it was the tightest, the TOB would squeek--when i'd lift up on the clutch to give it slack, plus with the FWA, the squeek would stop and you could actually see the TOB not moving like it's supposed to--which leads me to believe i do, in fact, need the steeda quadrant because either the 2nd or 3rd hook would give the slack i need. i'm probably gonna order today or tomorrow and install next week sometime. i'll let you guys know. thanks for the help, i sure do appreciate it :SNSign:
legalize420
1,541
South Florida
Dec 2, 2005
#18
  • Dec 2, 2005
  • #18
how can you see the TOB? im not 100% sure but im think its in the cluth .
Blackened302
1,439
South TX
Dec 2, 2005
#19
  • Dec 2, 2005
  • #19
you remove the plate on the underside of the tranny. my bro-in-law's got a pit, so it makes it even easier.
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
Clutch adjustment
  • Bill1xl
  • Oct 12, 2024
1994 - 1995 Specific Tech Oct 12, 2024
