  • 2.3L (N/A & Turbo) Tech
Clutch help
  • Thread starter Thread starter tlpilot
  • Start date Start date Apr 19, 2007
tlpilot
34
Denver, CO
Apr 19, 2007
  • Apr 19, 2007
I finally got around to putting the t5 in the 2.3. I have what I believe to be the SVO bellhousing. It has a little mini cable that pulls the clutch fork. This little cable is hooked to arm that attaches to the clutch cable.
What type of connector do I need to connect the cable to the pivot arm on the side of the bell housing?
I have the four wires that plug up to tranny but do I jumper the two that I don't need to each other?
Any help is appreciated.
Thanks,
Brew
goland55
2,847
New Bedford, MA
Apr 24, 2007
  • Apr 24, 2007
Does your clutch cable have a ball end to it? If the svo bell is like the other 2.3 bells then you should be able to connect that ball end to it. If you happen to have a 5.0 clutch cable (threaded end I believe) it won't work without modification (if it can work at all, I dunno).
From what I know you jumper the two wires that aren't used. If you haven't. I suggest you check out stinger's write up on the swap here: http://www.stinger-performance.com/howto.html
M
Help with bellhousing ID
  • mystic122468
  • Jul 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 1, 2025
AeroCoupe
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Dec 26, 2025
AeroCoupe
R
Drivetrain Clutch
  • Robman8028
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jul 2, 2025
AeroCoupe
TKX Install in the Coupe
  • AeroCoupe
  • Apr 12, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2026
F
Please help 00 mustang 3.8 v6 T5 manual transmission Tail housing cracking
  • FF-DC00
  • Jan 2, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 2, 2025
General karthief
