Clutch Issue
As stated by Dan earlier the Fiore is a good product. I currently run a UPR adjuster and quad myself and have no complaints. I know you are on a tight budget, but a firewall adjuster is a relatively cheap mod. The UPR setup is $40.
U.M.
Killy this is a common issue.. you have two choices to fix this..
1. buy a aftermarket quad and a NEW FORD cable. or
2. follow these instructions to manually adjust the stock quad.
http://www.corral.net/index.php?option=com_content&task=view&id=97&Itemid=26
There is a TSB out there for this problem. I do not know if they added your year mustang to the TSb list yet but they should make it for all of them.
what happens is the crappy stock quadarant looses it's ability to self adjust properly and the cable is too loose.
