  • SN95 4.6L Mustang Tech
Clutch noise
  • Thread starter Thread starter sn_95Stallion
  • Start date Start date Oct 30, 2004
sn_95Stallion
  • Oct 30, 2004
I was hoping I might be able to get some help with diagnosing an irritating squeeking noise coming from the cluth when you release the pedal. If youre sitting in neutral with your foot off the clutch, there is a faint belt like squeek coming from the clutch. Its not a constant squeek, instead its in intervals and the intervals become more frequent proportional to increases in RPM. If you put your foot on the clutch pedal and push it just far enough to put tension on the cable the squeek goes away. However lift your foot off and it comes back. It does it while I'm cruising too and goes away during shifts. The performance of the car is sound. there is no faults or differences in the operation. I was just hoping anyone might have experienced this before and could give me some insight. I really appreciate it
Thanks
sn_95Stallion
Sharkster
127
  • Oct 30, 2004
Sure sounds like the throwout bearings to me
sn_95Stallion
  • Oct 30, 2004
Thats what my initial thought was. I got under there with a stethescope and listened.
Its loudest in the bell housing of the trany. So thats probably what it is.
A
Ajax_02GT
90
Austin, TX
Oct 31, 2004
  • Oct 31, 2004
You can adjust the stock quadrant mechanism to put more tension on the TOB to keep it quiet. That's what I have done and my TOB has been nice and quiet with no ill effects otherwise. Do a search for my posts as I have listed how to adjust it (it's easy).
You could also swap out the stock quadrant with an aftermarket quadrant and firewall adjuster to to the same thing.
sn_95Stallion
  • Oct 31, 2004
Hey thanks Ajax_02GT,
That worked brilliantly. I can't believe how easy that was. I should have done it sooner.
I appreciate all your help
A
Ajax_02GT
90
Austin, TX
Nov 1, 2004
  • Nov 1, 2004
No problem, glad it worked out. I bought a Steeda quadrant and firewall adjuster to take care of the problem but haven't installed them yet because the "free" adjustment has worked so well.
M
Fox Engine Fan Noise
  • mcalvo
  • Aug 31, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 6, 2024
limp
Drivetrain Vibration in clutch pedal and shudder noise when engine is lugging
  • AnthonyA1234
  • Jan 8, 2024
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Jan 8, 2024
AnthonyA1234
R
03 Mach 1 (tremec 5 speed) - Clutch/transmission noise help
  • rvrstxyz
  • Jan 21, 2023
3K
1996 - 2004 SN95 Mustang -General/Talk- Jan 23, 2023
weendoggy
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
J
Drivetrain Shut off noise
  • Jaycee86!
  • Apr 3, 2023
4K
Fox 5.0 Mustang Tech Apr 5, 2023
