Wow bud, we need to get you to open up a little. These one-liners make it hard to figure out what you mean.
If you hear a whack noise if you dump the clutch a little during a shift (like you shift gears and then let the clutch pedal out real fast afterwards), that is normal. You are loading the driveline up. When the clutch is released slowly, the clutch absorbs vibration and eases the re-engagement of power. When you dump it, the vibes and shock are transfered to the drivetrain.
You should always examine your DS (u-joints, etc) to be safe.
Good luck.
