Clutch pedal loose
  • Thread starter Thread starter ajaffer
  • Start date Start date Oct 18, 2008
A
ajaffer
28
  • Oct 18, 2008
I got into my 1993 Mustang 5.0 and pushed down the clutch pedal, it made this snapping noise, and now its loose. Its in a shopping plaza parking lot, could I fix the problem in the parking lot? Is it just some spring I have to reattach to the pedal?
HISSIN50
34
129
Oct 18, 2008
  • Oct 18, 2008
The quadrant or pawl teeth probably stripped. You could try pulling up on the pedal to see if it will readjust and re-engage. Just note that if this works, the same thing might happen again at any time while trying to drive.
An aftermarket quadrant and Firewall Adjuster will take care of the issue.
Good luck.
A
ajaffer
28
  • Oct 18, 2008
Good luck.
Appreciate the help, how much do you think that will run me?
EMW150
2,020
Roaring Spring,PA
Oct 18, 2008
  • Oct 18, 2008
80.00 from UPR. You can get the firewall adjuster, cable, and quadrant all in one shot.
Unlimited Performance Racing Products On-Line - Firewall Adjusters
2000xp8
SN Certified Technician
Aug 8, 2003
8,076
1,658
194
NJ
Oct 18, 2008
  • Oct 18, 2008
I had this happen with my clutch, it did manage to come undone so i could go home.
As far as an aftermarket setup, i dont like them, and prefer the stock setup. I do have aftermarket based on the fact that i have a very heavy clutch, and would break it again.
But if i had a king cobra or centerforce, i certainly would replaced the stock stuff.
I also don't drive my car often, so adjusting it manually isn't all that big of a deal.
EMW150
2,020
Roaring Spring,PA
Oct 18, 2008
  • Oct 18, 2008
You kiddin me? Can you even buy the stock junk anymore?
HISSIN50
34
129
Oct 18, 2008
  • Oct 18, 2008
I really like the MM kit (long cable, FWA and quadrant). I would have tried the Fiore stuff last time around but it was backordered at the time.
The MM FWA and quadrant are less than 70 bucks IIRC, and the Fiore stuff is just a little bit more.
I agree with Eric - I would not want to purchase the stock stuff. It was a cost-effective way for them to do linkages, but the aftermarket stuff is far more tractable in the long term. One tow home can cost what buying new aftermarket stuff cost.
MHO.
Good luck.
2000xp8
Aug 8, 2003
8,076
1,658
194
NJ
Oct 18, 2008
  • Oct 18, 2008
People been getting by with that stock junk for over 20 years now.
How bad could it of been?
The stock junk is plenty good for most average mild street cars.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
