Drivetrain Clutch Pedal noise when pressed?
3ricchu
17
My vehicle has recently developed a squeak that occurs every time the clutch pedal is pressed. It occurs regardless of how quickly the clutch pedal is pressed, and only occurs during the stroke of the pedal travel. It makes no noise at all when it is released, or all the way down (which indicates to me it isn't the TOB).
Any ideas? Clutch quadrant? Cable? Clutch itself going out?
Also anyone have any experience with the Exedy Mach 400 clutch?
Thanks in advance!
The release arm pivot/fulcrum has probably dried out. The noise could also be originating where the TOB rides on the trans front bearing retainer.
You could remove the inspection cover and have a buddy cycle the pedal while you listen and poke around.
Reactions: Kilgore Trout
