Clutch pedal question
  • Thread starter Thread starter stang2841
  • Start date Start date Nov 14, 2004
stang2841
708
palm harbor florida
Nov 14, 2004
  • Nov 14, 2004
well I bought all the parts for the T-5 swap and I got a few questions, right now it has a aluminum FMS quadrant, and a FMS clutch....
My friends car the it picks up when the clutch pedal is about equivalent to the brake pedal if not higher......
how can I make that happen on my car? and keep it that way? what kit to buy? The FMS clutch is way to stiff to have to bring the clutch pedal halfway to the ground or to the ground for it to pick up....
can anybody give me tips on when im installin this for what to do to get it to pick up way up high?
if I got to buy a whole new set up No Problem, because this is going to be a daily driver
jpctln
198
StL, MO
Nov 14, 2004
  • Nov 14, 2004
You'll need to buy a billet firewall adjuster to adjust your clutch engagement point. What it does is replace the rubber gromet on the firewall where the clutch goes through with a 2 piece, threaded adjuster. To make the clutch engage higher, you'll need to screw it outward, thus putting more tension on the clutch cable.
stang2841
708
palm harbor florida
Nov 14, 2004
  • Nov 14, 2004
is it only billet that has this? could you use a stock cable?
HISSIN50
34
129
Nov 14, 2004
  • Nov 14, 2004
yes, you do use the stock non adjustable cable.
good luck.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Swapping clutch pedal hanger-
  • woodsnake
  • Sunday at 3:55 PM
Classic Mustang Specific Tech Sunday at 3:55 PM
woodsnake
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
