Clutch Pedal Rod - Firewall Hole Location?
All,
I am installing a stock clutch pedal / lever / rod in my '68 coupe. The car was originally an automatic so I will need to drill a hole in the firewall for the clutch pedal rod. I am using all stock parts, and this is going to a 302 with a 4 speed top loader.
Does anyone have a picture of where the rod should be on the firewall? It looks like the best place is pretty close to the steering col.?
Thank you!
All,
Thank you!
This ought to do. There's a dimple marking the center of the hole. Make sure you make it the right size to fit the rod boot:
