Clutch pedal spring on T5 cable ?
Rapid
297
Columbia, SC
Do I need the "helper" spring on the pedal with a cable conversion?
Can I take the old brake pedal out, install bushings, and put the new brake and clutch pedal in w/o taking the pedal bracket out?
Thanks guys,
I think its more of a function of the type of pressure plate. If you have a diaphram type of pressure plate, then you should remove the under dash spring. You didn't say what year but on a '65/'66, you can remove the pedal upstop, then swing the pedal horizontal (disconnect the linkage first) and the spring should just about fall off.
Yes, you can install the bushings with the the bracket in the car, as long as the bracket isn't really worn, then obviously you'd have to fix the bracket.
Thanks,
It is a 65 and does have a diaphram clutch.
