  • SN95 4.6L Mustang Tech
Clutch Pedal Vibration???
  • Thread starter Thread starter mikes2008gt
  • Start date Start date Jan 21, 2004
mikes2008gt
706
Arlington, Texas
Jan 21, 2004
  • Jan 21, 2004
Does anyone else's clutch pedal make a vibrating noise while driving? Mine does unless I hold the side of my foot against the pedal. It's buggin teh freakin' CRAP outta me! I HATE RATTLES!!!! Any ideas as to how to fix this?
Thanks!
downsouthman1
643
Texas
Jan 21, 2004
  • Jan 21, 2004
My stock clutch did that too. Hopefully that'll be fixed Friday morning when I pick up my car w/ the SPEC stage 2 clutch installed.
mikes2008gt
706
Arlington, Texas
Jan 22, 2004
  • Jan 22, 2004
Anyone else had this with their stock clutch pedal?
Gatorman1369
61
Gainesville, Florida
Jan 22, 2004
  • Jan 22, 2004
Mine does too but I thought it was normal, everything else rattles so why not this. Let us know the outcome.
Thanks.
BLKVERT
407
SATX
Jan 22, 2004
  • Jan 22, 2004
My clutch pedal rattles or shall I say vibrates occasionally, is this something I need to be concerned about?
T
TeknoMage
50
  • Jan 22, 2004
Mine rattles as well (under medium to heavy braking). I'm pretty sure it can be fixed with a clutch adjuster kit from Steeda but I haven’t had a chance to get one yet.
As far as I know, it's just a lack of tension on the clutch pedal.
Firemanz
Only you can prevent Forest Fires!
4,105
San Antonio, TX
Jan 22, 2004
  • Jan 22, 2004
My 2000 GT did that when I got rid of it, my 2003 hasn't done it yet......*knock on wood*
mikes2008gt
706
Arlington, Texas
Jan 22, 2004
  • Jan 22, 2004
So has anyone ever taken their's in to the dealer about this? Mine's out of warranty. Otherwise, I would. My car only has 44K, so it surprises me this would be a wear issue or something getting loose in the linkages.
Cars&Guitars
41
Colorado
Jan 22, 2004
  • Jan 22, 2004
I put on the Steeda clutch adjuster, quadrant and cable and it went away. I think it is just due to lack of tension on cable.
oogtdude
Banned
Jun 9, 2002
1,626
#10
  • Jan 23, 2004
  • #10
its doing it alot in the cold..but not so bad in summer..i get my mach this week hope she dont do it
jfranci3
1,146
Indy
Jan 23, 2004
#11
  • Jan 23, 2004
  • #11
Some say it's because of the bushings used on the pedal assembly.
dahun
102
California
Jan 23, 2004
#12
  • Jan 23, 2004
  • #12
My '96 had the same problem....
... took it to the dealer, and turned out to be a pressure plate problem. Not sure of the exact cause, but I remember it had something to do with the fingers on the diaphragm that engage the throw-out bearing.
Good luck.
Thanks!
Craig Mack
Busted Buffing the Bishop
801
Lake Mary, FL
Jan 23, 2004
#13
  • Jan 23, 2004
  • #13
Good luck.
That's EXACTLY my problem. How did you fix it? Did Ford say it was hurting anything?
lman657
85
#14
  • Jan 24, 2004
  • #14
Mine did it too, but doesn't with the new centerforce clutch
N
nuke_em
76
Utah
Jan 24, 2004
#15
  • Jan 24, 2004
  • #15
Mine 01 had the same exact problem, i took it to ford and they replaced the whole clutch assembly w/ pressure plate etc. That fixed the problem for about 3 months then it came back, so after taking it back to ford another couple of times they finally decided it was my flywheel. This was about six months ago and i haven't had any problems since then.
TheDBA
23
The act or process of locating
Jan 24, 2004
#16
  • Jan 24, 2004
  • #16
My 2001 V6 convertible did the same thing, not annoying enough to take it in. Seemed to happen at certain rpms - not constant. 2004 GT vert doesn't have the problem.
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
