clutch problems
betke76
Oct 23, 2004
241
9
laurel, md.
hey guys i am having a issue and looking for some opinions before spending any cash. i have a 90GT i just bought and looking for advice. my clutch pedal is extremely hard to press, and the car doesnt start moving till the pedal is almost all the way let out. i have no idea what clutch is in the car, i assume its stock because car is all stock except for exhaust. stock cable,adjuster everything. 140,000 miles. i want to start driving this car alot and want it to be reliable. I am almost positive it's a worn out clutch, but want opinion's before buying a new clutch. could it be anything else? ooh yea i also grabbed clutch pedal and pulled up on it to make sure its adjusted.
Clutch adjustment
Do the clutch adjustment first before considering any other problems. With the stock plastic quadrant and cable, pull up on the clutch pedal until it comes upward toward you. It will make a ratcheting sound as the self adjuster works. To release to tension of the stock quadrant, use a screwdriver to lift the ratchet paw up and out of engagement with the quadrant teeth.
A binding clutch cable will make the clutch very stiff. If the cable is misrouted or has gotten too close to the exhaust, it will definitely bind.
I would try releasing the quadrant and see if you can adjust it little by little to see if it improves. If it does not, then replace the stock cable & quadrant with aftermarket parts.
Clutch pedal adjustment with aftermarket quadrant and cable:
I like to have the clutch completely disengaged and still have about 1.5” travel left before the pedal hits the floor. This means that I have only about 1” of free play at the top before the pedal starts to disengage the clutch. Keep in mind that these figures are all approximate. When properly adjusted, there will not be any slack in the clutch cable. You will have 4-15 lbs preload on the clutch cable.
The quadrant needs to be replaced if you use any type of aftermarket cable or adjuster. My preference is a Ford Racing quadrant, adjustable cable and Steeda firewall adjuster. The adjustable Ford Racing cable is just as good as the stock OEM cable. It allows a greater range of adjustment than a stock cable with a aftermarket quadrant and firewall adjuster. Combined with the Steeda adjuster, it lets you set the initial cable preload and then fine tune the clutch engagement point to your liking without getting under the car.
Using a stock OEM cable, firewall adjuster and a single hook quadrant may result in not having any free pedal travel before the clutch starts to disengage. I found this out the hard way.
The binding common to adjustable cables is often due to misplacement of the adjusting nuts on the fork end of the cable. This will also cause the cable to wear and fray. Both nuts should be on the back side of the fork so that the domed nut faces the fork and the other nut serves as jam or locknut to the domed nut.
