Anyone have a link handy that shows installation of this set up. Not looking forward to wrecking my back this weekend installing this thing. But, I think it's going to happen.
A guy posted this link on my local club board.
http://www.modernengineuity.com/forums/showthread.php?t=707
It's easier after you've done a couple of them beforehand, of course, but even the first time around isn't all that hard. The biggest PITA is getting that stupid little stock plastic pawl off its stud. The stock quad is easy to remove - pull the pin, unclip the spring, and it practically falls off. The pawl is a bugger because getting that spring off is awkward, and then you have to rotate the thing upside-down and push the clutch pedal as farrrrrrr to the floor as you can to get enough clearance on the side to slip it off the stud and past that metal support piece under the dash. (You'll know it when you see it.)
I've never had to pull the seats when I've done it, just move 'em back all the way ... but then again, I'm just a lil' guy.![]()
