Clutch Question
  • Thread starter Thread starter Foundmy84
  • Start date Start date Aug 2, 2007
F
Foundmy84
Nova Scotia, Canada
Aug 2, 2007
  • Aug 2, 2007
Hi all, not terribly mechanically able however have alittle knowledge. Anyhow my question. I have an '84 5.0 5spd ... 2weeks ago had the ring gear on the flywheel replaced ( the old starter chewed the teeth off it) when having it replaced they noted the throwout bearing was alittle noisey but the clutch and pressure plate were in good shape so we had the throwout bearing replaced... after having everything put back in place the clutch started acting up ( almost like the pedal itself I figured it must be the cable, as it wasn't like the pedal would come all the way back however the pedal would if you pulled it back with your toe...so I stopped shoving the clutch as far and it seemed to work then tonight.. when shifting it made a snap sound when i shoved the pedal in and again when I shoved it in again same snap sound clear and distinct snap, then the 3rd time a loud snap and pedal right to the floor no tension whatsoever however the pedal comes all the way back when pushed in. My question... last year I replaced the linkage under the dash for the clutch.. Does it sound to you folks like my cable broke?
ls1beater4eva
334
mooresville
Aug 2, 2007
  • Aug 2, 2007
well just wundering have you replaced the quadrent with a aftermarket one bc i know my stock plastic one did the same thing and then just stayed on the florr till u pulled back up sometimes if you cable was broke u would have no pedal affort at all .
F
Foundmy84
Nova Scotia, Canada
Aug 2, 2007
  • Aug 2, 2007
There is no pedal at all it just swings freely there is no tension at all, I replaced the quadrent last year ( still it was a factory one and plastic) however when it was frigged last year it made a grinding/ slipping sound and there is no sound at all there now and liek i said you can push the clutch pedal down and it comes back up with no noise so I am thinking that is still intact?
WTB Wanted - Foxbody clutch pedal
  • TTSaleen
  • Aug 4, 2026
  • Want to Buy
Want to Buy Aug 6, 2026
General karthief
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Swapping clutch pedal hanger-
  • woodsnake
  • Nov 8, 2026
Classic Mustang Specific Tech Nov 8, 2026
woodsnake
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
