Clutch Question
Hi all, not terribly mechanically able however have alittle knowledge. Anyhow my question. I have an '84 5.0 5spd ... 2weeks ago had the ring gear on the flywheel replaced ( the old starter chewed the teeth off it) when having it replaced they noted the throwout bearing was alittle noisey but the clutch and pressure plate were in good shape so we had the throwout bearing replaced... after having everything put back in place the clutch started acting up ( almost like the pedal itself I figured it must be the cable, as it wasn't like the pedal would come all the way back however the pedal would if you pulled it back with your toe...so I stopped shoving the clutch as far and it seemed to work then tonight.. when shifting it made a snap sound when i shoved the pedal in and again when I shoved it in again same snap sound clear and distinct snap, then the 3rd time a loud snap and pedal right to the floor no tension whatsoever however the pedal comes all the way back when pushed in. My question... last year I replaced the linkage under the dash for the clutch.. Does it sound to you folks like my cable broke?
well just wundering have you replaced the quadrent with a aftermarket one bc i know my stock plastic one did the same thing and then just stayed on the florr till u pulled back up sometimes if you cable was broke u would have no pedal affort at all .
There is no pedal at all it just swings freely there is no tension at all, I replaced the quadrent last year ( still it was a factory one and plastic) however when it was frigged last year it made a grinding/ slipping sound and there is no sound at all there now and liek i said you can push the clutch pedal down and it comes back up with no noise so I am thinking that is still intact?
