Clutch?
Irrational
26
Neptune NJ
Ok Just bought car yesterday. Putting in a new clutch need help asap ordering parts today. Yes I searched this topic but was all over the place this guy this that guy that.
1. What Parts do I need
a.Clutch Kit which one (Is it a bitch w/o alighnment tool)
b. Cable adjuster yes/no
c. Have stock fly cut or replace it
2. Pro 5.0 or steeda
3. Which ud pulleys are best
4. Should I A/C delete?
5. Should I delete Smog?
thanks ahead guys
Promotion or mcloud clutch...they are the best. If you have the money go alum. flywheel it makes a world of difference. Most kits should come with a alignment tool (yes you need it). That is to say I have never come across a kit that does not come with an alingment tool but I bet a kit like that exists somewhere.
thanks ahead guys
1a. I would run a KC clutch - I liked it a good bit more than my HD clutch. I seem to recall that you have a pretty stock car - I dont see the need for fancy-schmancy clutches with such a set up.
1b. You can get a quadrant and FWA. I would use the Fiore pieces but they are a little pricier than other stuff.
1c. Depends upon the existing flywheel. You can probably have it turned. A Blanchard grinder is the best means of doing that.
2. Though I have not tried one, I would try an MGW. Or a 5.0 with a Kona handle.
3-5. Up to you. Depends upon smogging in your area, you exact set-up, etc.
Good luck.
Ok thanks alot guys so so far I am ordering the KC clutch (good enought for now)
I am picking up a stock cable
will pick up shifter at local shop
Only other thing is pulleys (BBK Or March) Have heard good things about march
march are nice... they're the only ones i've had, but they are aluminum reducing rotating mass over steel ones, plus i havnt had any charging or cooling issues with them, they are pretty pricey though
Ok yesterday I ordered:
Kc Clutch + alighnment tool
New K&N For CAI
March UD pulleys
3:73's
Rear Main seal
Thanks for the help guys couple more quick ones.
I am going to make another order today:
I wanted to get a new clutch cable and I keep hearing oem is the best. Well went threw how to's and found this ( www.buyfordracing.com sells an OEM cable and clutch fork for $40 – 7553-A302 ). Its listed as an 87-93 part. But I have noticed all the other kits are sold as 79-95. So will this kit fit my car? I am also ordering all new arp bolts for installation.
