  • 1994 - 1995 Specific Tech
Cluth cable snapped....
  • Thread starter Thread starter The Green GT
  • Start date Start date Nov 23, 2008
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Nov 23, 2008
  • Nov 23, 2008
I had been hearing a small popping every time I pressed the clutch for the past few days, so I wasnt surprised when it snapped. Luckily I was 20 feet from my house and a few blocks from my moms house. So I just went to my moms and got her car.
So now I need a new cable. What brand would you recommend? I dont really need an adjustable one since I already have a FWA and quadrant. And the cheaper the better.
Thanks guys.
F
fish254
237
Brooklyn NY
Nov 23, 2008
  • Nov 23, 2008
i had the steeda one and a cheep ebay cable both of them broke on me now i have a factory ford cable yea it cost more but u cant compare the quality of the factory cable to any thing
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Nov 23, 2008
  • Nov 23, 2008
I've had a BBK cable for almost a decade now without any issues.
Kurt
HISSIN50
34
129
Nov 24, 2008
  • Nov 24, 2008
MM universal.
divit250r
314
Columbia City, IN
Nov 24, 2008
  • Nov 24, 2008
HISSIN50 said:
MM universal.
The single best change I've made to the car. Smooth as silk now.
Scott
The Green GT
1,269
Louisiana
Nov 24, 2008
  • Nov 24, 2008
What about the Ford Racing one?
Ford Racing M-7553-C302 - Ford Racing Clutch Linkage Upgrade Kits and Accessories - summitracing.com
And where could I get the MM one? I cant find it on Summit.
HISSIN50
34
129
Nov 24, 2008
  • Nov 24, 2008
I've used the Ford adjustable cable before (with an old school SVO single hook quadrant). I thought it was ok but it in no way compared to the MM unit. With as many times as a clutch pedal is depressed, the extra cost (of the MM cable, and your choice of FWA if needed) is worth it.
Maximum Motorsports :: The Leader In Mustang Performance Suspension
I think the universal cable is like a MMCL 11.
I would like to use this cable with a Fiore clicker FWA. They were backordered when I got my last FWA or I'd be running one.
ProKiller
3,064
15
78
PA
Nov 25, 2008
  • Nov 25, 2008
don't bother with the steeda cable. absolute crap IMO. when this one goes i'll be getting a MM
sage2k
645
Baton Rouge, LA
Nov 25, 2008
  • Nov 25, 2008
Mine broke, so I was forced to get one locally. Only one I could find in stock at a shop was a Steeda one, 50$, so far so good.
The Green GT
1,269
Louisiana
Nov 25, 2008
#10
  • Nov 25, 2008
  • #10
I have the Fiore FWA and quadrant thanks to you recommending them a long time ago. I like them so far. So Ill probably get the MM one.
fyassine
331
Austin, TX , US
Nov 25, 2008
#11
  • Nov 25, 2008
  • #11
I have gone through 3 clutch cables including the one from MM. Although it costs more, you can't beat the stock clutch cable.
The Green GT
1,269
Louisiana
Nov 25, 2008
#12
  • Nov 25, 2008
  • #12
Thats what Ive always head.
Although thats the one that just broke. But it is like 14 years old lol.
HISSIN50
34
129
Nov 26, 2008
#13
  • Nov 26, 2008
  • #13
Any chance there's a heat or routing issue? 3 cables is a lot to go through.
(I didn't post to be confrontational, but just make sure there isn't some other issue. I figured you thought of other issues already, but it never hurts to ask.)
fyassine
331
Austin, TX , US
Nov 26, 2008
#14
  • Nov 26, 2008
  • #14
No worries!
Just to make sure it was routed correctly, I took a picture of the routing of the original cable, before I touched it.
The original cable did get a bit close to the header but worked fine for about 10 years before snapping. I first tried a cable from autozone, which made the pedal extremely stiff and eventually snapped.
I tried the same thing from MM and it only lasted for about 3 months before doing the same. I bit the bullet and ordered an original oem cable from MM and it has been fine now for the past two years or so.
I am not trying to down the MM cable, only described how my situation played out for anyone that runs into the same problem.
94Silverbullet
488
MD
Nov 29, 2008
#15
  • Nov 29, 2008
  • #15
Thanks guys.
I have a new BBK with quadrant for sale, but to be honest, I haven't had good luck with them. I've gone through a few. I have the MM one on my car, and hadn't had any troubles since.
1SAVG93
48
Vacaville (Bay Area), Ca
Dec 2, 2008
#16
  • Dec 2, 2008
  • #16
i went through 2 adj. clutch cables and snapped them both and now back to the stock cable and works just like new. everyone that uses adj. say they snap
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Today at 8:39 AM
squeak93
