Expired Cnc Dual Master Cylinder & Remote Reservoirs Brake Assembly
68GT500KR_Vert
5 Year Member
Aug 21, 2006
353
60
59
Virginia Beach, VA
This is brand new - I only test fitted it to make sure it fit with the engine. I've decided to run a hydratech brake system instead. I paid $500 for the unit. PM me an offer.
This CNC Dual Master Cylinder Brake Assembly is a direct bolt on for most non-power brake Fords and Mercury cars from 63-74. - this was test fitted on my 68 Mustang
  • This unit does not require the use of a proportioning valve.
  • Brake bias is adjusted with Master Cylinder balance bar.
  • Adjustable balance bar for dial in of front and rear pressure ratios.
  • Increased pedal feel with less effort (The general consensus of the CNC cylinders is that the pedal effort would be generally less than manual brakes but require a little more effort than power brakes)
  • Eliminates the need for power brakes.
  • A separate Master Cylinder for front and rear.
  • Cylinder size 3/4" for disc brakes
  • Double billet reservoir kit - with hoses
  • High strength severe duty design.
  • Top quality rod ends included.
  • Adjustable brake push rod
