Cobra Booster Install
  • Thread starter Thread starter Shaolin Crane
  • Start date Start date Nov 21, 2008
1 of 2 Next Last
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Nov 21, 2008
  • Nov 21, 2008
Wel no questions just comments today, installed a new booster from a 95 cobra in the fox today and all i can say is WOW unbelievable stopping force measured my stopping distance of 80-0 in the distance of about 2 parked silverados that were on the street i was testing the booster on, so i would say it was a 70 dollars well spent if you guys have any questions about the install please feel free to ask me.
Nova
128
  • Nov 21, 2008
fitting a 93 cobra booster in my car was hard enough!
ShortThrow50
923
Pa
Nov 21, 2008
  • Nov 21, 2008
I feel as though my stock booster doesnt get enough vaccum after i swapped h/c/i. its hard to push the brake pedal down. Will one of these boosters fix this problem
93 LX
3,081
Norwalk, CA.
Nov 21, 2008
  • Nov 21, 2008
Get at vacuum Reservoir.
ShortThrow50
923
Pa
Nov 21, 2008
  • Nov 21, 2008
I just bought one from summit but its a little bigger than i expected. I cant find any place it will fit bro. Im thinkin i may see if it will fit behind the fender.
the pony boy
358
Nov 21, 2008
  • Nov 21, 2008
on the fox cars the 93 booster is the way to go.the bolt holes line up so theres no need to enlarge the holes to fit one from other years.i wish i new that before i put a 95 in mine. phil
Mustang5L5
Mod Dude
Feb 18, 2001
43,347
18,082
224
Massachusetts
Nov 21, 2008
  • Nov 21, 2008
The 93 Cobra and SN95 boosters are physically larger so they "store" a little more vacuum adding to pedal force. They are really a good upgrade even with stock brakes.
If you are lacking vacuum however, you should install a vac reseviour.
Nova
128
  • Nov 22, 2008
the vaccuum issue is coming form the larger cam. and yes it would make the pedal alittle stiffer. you can try a different master cylinder that will give you more mechanical force to help overcome the lack of assist. a 94/95 v6 unit would help the most. couple that up with a larger booster and you should notice a big difference. a vaccuum canister
(or pump if you really wanna go all out) would help as well.
warriorpluto
267
monroe.LA
Nov 22, 2008
  • Nov 22, 2008
so would a reman for a 93 from autozone work better to install in my 87?
LiquidGT
368
Near STL hell
Nov 22, 2008
#10
  • Nov 22, 2008
  • #10
Really?
I have a 94 booster laying around in my 5 lug collection pile. So I can install it now on my stock brakes for the time being and be alright?
Yes, the '93 Cobra that is; the 94-95 booster is the same except you'll need to elongate the holes in the firewall some to get it to fit. The 94-95 is easier to find and it may be cheaper.
R
Rick James
172
burlington new jersey
Nov 22, 2008
#11
  • Nov 22, 2008
  • #11
Hey guys, how does this set up sound? 93 cobra booster ,94/95 master cylinder,Maximum motorsports 3-2 adapter,94-95 gt/v6 spindles,hubs ,calipers, rotors and the flexible/braided lines for the sn-95 to fox conversion ?For now the rears are staying drums.My car is 5 lug now with moser axles and ranger drums out back and ranger rotors up front but the stock 4 banger brakes are just scary at the track.
warriorpluto
267
monroe.LA
Nov 23, 2008
#12
  • Nov 23, 2008
  • #12
LiquidGT said:
Really?
what about the master cylinder? what kind do i get? 93 cobra too?
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Nov 27, 2008
#13
  • Nov 27, 2008
  • #13
well my cost on parts was 70 for a new one my guy said he wasnt able to get a new one so i didnt mind the extra work fitting it in thing stops hard now and i dont regret it
Chuckman
GTFO you fat, heavy bastard
1,604
1,002
173
st. louis, mo
Nov 28, 2008
#14
  • Nov 28, 2008
  • #14
why do people keep saying that the bolt holse dont need to be slotted for a 93 booster? i had to enlarge all of mine to give it even a chance of going in, and i still had to give it a few taps with the deadblow to get it in?
that being said, that was one upgrade that was definetly worth the money and hassle. drove around for close to a year with the stock booster on a cobra cylinder, it sucks having to use your whole weight on the brake pedal just to keep from going backwards down a hill at a stoplight.
Chuckman
1,604
1,002
173
st. louis, mo
Nov 28, 2008
#15
  • Nov 28, 2008
  • #15
yes, 93 mc, and youll need a 2-3 port conversion, look on maximum motorsports site for a kit (expensive though) or make you own, t fitting a a bit of brake line will make it pretty easy if you have the slightest idea of how to make the ends.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Nov 28, 2008
#16
  • Nov 28, 2008
  • #16
same issue i had, so i changed it some may say the 94 is the better route but a warning, it does NOT go in easy but is well worth it when its in.
J
JerryDaugherty
309
Near Dallas
Jan 17, 2009
#17
  • Jan 17, 2009
  • #17
what was the easiest way to get the top two bolts off behind the dash?
FoxBodyGT
71
Austintown, Ohio 44515
Jan 17, 2009
#18
  • Jan 17, 2009
  • #18
I have my engine out and I'm hoping putting in the booster/MC from a 94 v6 will be easier that way.
Blandnuts
I don't swallow; I only swoosh
1,172
124
124
FloorDuh
Jan 17, 2009
#19
  • Jan 17, 2009
  • #19
I used a wrench and was wishing the whole time I had ratching wrenches. I would suggest taking out the seat too if you care about your back. Getting stuff off isn't near as hard as getting them back on . Overall, it's not that hard...just frustrating.
Fred
Chrome_Rust
530
Findlay, Ohio
Jan 17, 2009
#20
  • Jan 17, 2009
  • #20
on my 93 i am doing a SN95 dash swap, i am also doing the brakes from a 95 V6 car. can i use the pedal assy. and booster, and just re-route my lines to make them follow the same path as the 95? their is no ABS. should i use the prop. valve? After reading this thread i am going to rob the MC & Booster. My car is a 5sp.
1 of 2 Next Last
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
