cobra intake install
  • Thread starter Thread starter Daniel50
  • Start date Start date Aug 23, 2005
Daniel50
716
Discovery Bay, CA
Aug 23, 2005
  • Aug 23, 2005
finally broke down and bought a ford racing cobra intake manifold. anyone know where i can find a tech article on it. just like to have a guide while doing an install to fall back on. like to know all torque specs as well
Gixxer750
789
Saint John NB, Canada
Aug 23, 2005
  • Aug 23, 2005
Torque specs are 8lb then to 16 for the lower (I may be wrong this is off the top ofmyhead) and the upper is only 12-14lb I think. There is a pattern to it as well. I will try to post it up later.
Daniel50
716
Discovery Bay, CA
Aug 23, 2005
  • Aug 23, 2005
thanks but if i anyone knows for sure please post them up... and the tech article if possible
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 23, 2005
  • Aug 23, 2005
Pattern is simply inside out in a star pattern.
CManT1914
3,172
Killeen, Texas
Aug 23, 2005
  • Aug 23, 2005
94/95 Edelbrock install in the 94/95 FAQ section, should be the same.
Post #8
http://forums.stangnet.com/showthread.php?t=334773
Daniel50
716
Discovery Bay, CA
Aug 23, 2005
  • Aug 23, 2005
couldnt find it. anyone have a write up either?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Aug 23, 2005
  • Aug 23, 2005
The torque sequence is easy. There are 12 intake bolts with two rows of 6. You always alternate rows and start from the middle and work out. It doesn't matter which side is front or back.
(11) 5 3 1 8 (10)
9 7 2 4 6 (12)
Daniel50
716
Discovery Bay, CA
Aug 23, 2005
  • Aug 23, 2005
ok but nobody answers the question TORQUE SPECS AND TECH ARTICLE NOT BOLT PATTERN!!!!!!!!!!!!!!!!!!!!!!!!!!! lol
281pony
2,681
Oly, WA
Aug 23, 2005
  • Aug 23, 2005
6, 16, 24 pound on lowers. i always make about 6 passes at 24 pounds because it sucks down some more after the first pass.
cobradvm
245
Woodinville, WA
Aug 23, 2005
#10
  • Aug 23, 2005
  • #10
For someone running 12.95 with a 100 shot kit, and whatever other mods are listed in your sig, it sure seems odd that you can't slap on an intake without a tech article!
281pony
2,681
Oly, WA
Aug 23, 2005
#11
  • Aug 23, 2005
  • #11
also pick up a chilton/haynes manual. would save you all the hassle here of not knowing the torque specs.
Daniel50
716
Discovery Bay, CA
Aug 23, 2005
#12
  • Aug 23, 2005
  • #12
I can do it i just like something to fall back on in case i get confused. i do not have a manual and never done it before. I ran a 12.9 so that makes me a mechanic?
carbed87
215
#13
  • Aug 24, 2005
  • #13
yes... yes it does
9T3SVT
84
#14
  • Aug 24, 2005
  • #14
Close enough
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 24, 2005
#15
  • Aug 24, 2005
  • #15
Here's some tips...
Tools: a good torque wrench is a must have item. A razor blade scraper that holds a single edge razor blade from Home Depot or Ace hardware is another handy thing. Get a Chilton or Haynes shop manual - you'll need it for the bolt torques and patterns. The intake manifold has an especially odd pattern. You'll need access to a timing light to set the timing after you re-stab the distributor. Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
The A/C Compressor comes off with lines still connected. Mark all the electrical, smog and vacuum lines with tags to help you remember where to re-connect them. If you have a digital camera, take several pictures.
Whatever you do, don't skimp on cleaning the gasket surfaces. New gaskets need to seat against bare metal and not the residue left from the old gaskets in order to seal leak free. This is the most time consuming and tiresome part of the job. Look for little things that need to be replaced like the short hose from the thermostat hosing to the water pump, damaged vacuum lines and hose clamps that are rusted or broken.
Plan on cutting the thermostat to water pump hose, or removing the thermostat housing. Also plan on removing the distributor to get clearance to remove the intake manifold. Remove #1 spark plug, stick your finger in the spark plug hole and crank. When your finger gets air moving past it, stop cranking. Turn the engine until the timing marks line up with the pointer. Now you can pull the distributor out.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface, and on the side of the gasket that mates to the head. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together. Wala! no leaks, and no gaskets that shifted out of place.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit. The pintle caps fit either injectors with a pin sticking out the injector end or 4 with more tiny holes in the injector end. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
Consumable items:
Upper manifold gasket
Fel Pro 1250 or equal lower manifold gasket set.
Short formed hose between thermostat hosing and intake manifold
6 ft 7/64" or 1/8" vacuum hose
2 ft 1/2" heater hose
1 1/2 ft 5/8" heater hose
Blue Silicone sealer
ARP antiseize or equal for the bolts
4 each 3/4" hose clamps (spare item in case the old ones are bad)
4 each 1/2" hose clamps (spare item)
Vacuum line connections:
One large vacuum line from the upper front goes to the carbon canister
One large vacuum line from the rear goes to the vacuum tree.
One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
One small line in the rear goes to the fuel pressure regulator.
One small line in the rear goes to the EGR suction regulator.
One large line in the rear goes to the PVC valve.
Daniel50
716
Discovery Bay, CA
Aug 24, 2005
#16
  • Aug 24, 2005
  • #16
thanks thats more helpful. is it posible in anyway to not remove the distributor? cuz they said i had to remove spark plugs to do headers but i ended up taking out only 2
carbed87
215
#17
  • Aug 24, 2005
  • #17
yeah man, the distributor goes straight throuth the intake. just mark it and pull it out, being careful not to turn it. if all goes well than you can just stab that fugger back in there and not even have to worry obut timing.
CManT1914
3,172
Killeen, Texas
Aug 24, 2005
#18
  • Aug 24, 2005
  • #18
Well not exactly through the intake, but it is in the way regardless. When I did my intake swap way back when, I just used some whiteout to mark the position, then I dropped it back in that same way, and it started right up.
carbed87
215
#19
  • Aug 24, 2005
  • #19
oh yeah my mistake, i guess its been a long day
mrswivlepants
93
#20
  • Aug 24, 2005
  • #20
The hose pattern is a little funky too. Not exactly straight forward and nothing like stock. There's a post with a picture of how they run. Try to find it.
*edit*
here are the pics I was talking about. There's quite a bit of good install info in the link below the pictures.
http://eleanor.pro3i.com/showthread.php?t=545466&highlight=cobra+intake+install
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Fox Cobra wheels real vs. replicas
  • keel
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 9:43 AM
keel
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
