  • 1994 - 1995 Specific Tech
Cobra vs GT parts... tower brace difference?
  • Thread starter Thread starter ratio411
  • Start date Start date Apr 17, 2011
ratio411
3,870
73
109
Pensacola FL
Apr 17, 2011
  • Apr 17, 2011
Okay, so we put the stock Cobra intake on my son's 94 GT today.
I made sure to get the 94-95 Cobra intake so that it could go back together stock with a clean fit/appearance.
Well, that plan didn't work so well.
The tower brace won't go back on.
So, now I assume that the 94-95 Cobras had a different tower brace than GTs???
The car is a convertible GT, and the stock Cobra intake is on without any spacers or mods.
GTA_V6_Mustang
1,326
Miami, FL
Apr 17, 2011
  • Apr 17, 2011
yes it is a different one. when i did it on my old mustang what i ended up doing was getting a 351 MM strut tower brace.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Apr 17, 2011
  • Apr 17, 2011
Yeah, that is the sucky part, because aftermarket tower braces are pretty pricey. You can leave the strut tower brace off though. Most people say they can't even feel the difference.
Kurt
toyman
1,944
54
79
Vernon BC
Apr 17, 2011
  • Apr 17, 2011
I thought the 94-95 Cobras didn't have a STB.
Last5.0
404
Apr 17, 2011
  • Apr 17, 2011
They didn't come with one from the factory, but Ford Motorsports (alonge with a few other companies) made one to clear aftermarket intakes and it also clears the cobra intake. I have one. It goes around the front of the intake instead of over it like the stock brace does.
spartanpride
73
  • Apr 17, 2011
I've wondered that too, so no harm in just leaving the tower brace off??
ratio411
3,870
73
109
Pensacola FL
Apr 18, 2011
  • Apr 18, 2011
Well... the way I look at it is that Fox bodies never had an STB, and they were around in many forms for many years before 1994, and they were okay I suppose.
My son is a teenager, and doesn't 'hot dog' the car, nor does it even make enough power to twist anything up, so I am comfortable leaving it off.
We have been trying to give the car some power, but it is still a slug.
Last5.0
404
Apr 18, 2011
  • Apr 18, 2011
Do you have subframe connectors installed? That should be one of the first mods you do. It helps a ton with chassis stiffness.
tomustang
Psychotic Member
3,434
McLean Hospital
Apr 18, 2011
  • Apr 18, 2011
No harm, unless you got a convertible. The strut towers are strong enough to not need one
ratio411
3,870
73
109
Pensacola FL
Apr 18, 2011
#10
  • Apr 18, 2011
  • #10
Ours is a convertible...
What did Cobra verts use in 94-95?
ProKiller
3,064
15
78
PA
Apr 18, 2011
#11
  • Apr 18, 2011
  • #11
94-95 cobras didn't have a strut tower brace.
toyman
1,944
54
79
Vernon BC
Apr 18, 2011
#12
  • Apr 18, 2011
  • #12
As stated previously, the 94-95 Cobras didn't have a STB. I also have a 'vert with a KB bolted on and no STB. Had to remove it as it doesn't clear the KB. However, full length sub frame connectors (SFC's) should be welded in.
blksn955.o
3,263
st.louis mo 314
Apr 19, 2011
#13
  • Apr 19, 2011
  • #13
Yep, only the gt and cobra R had the strut tower brace from the factory.
Get full length weld in sub frame connectors if your worried about stiffness...then if want look for a aftermarket STB. Mine has been off for years and did not notice it one bit but I did have full length sub frame connectors installed prior to removing the STB.
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
  • AeroCoupe
  • Aug 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 1:04 PM
AeroCoupe
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
