  • 1994 - 1995 Specific Tech
Code 211? PIP Erratic
  • Thread starter Thread starter toppdogg_1
  • Start date Start date Aug 4, 2005
T
toppdogg_1
89
  • Aug 4, 2005
I got the codes ran on my car and it came back with a 211 PIP Erratic. The car has some problems starting at times but seems to drive fine. What exactly is the PIP and how much would it cost to replace it?
CManT1914
3,172
Killeen, Texas
Aug 4, 2005
  • Aug 4, 2005
I think it is the "profile ignition pickup" sensor, or something like that. It's in the distributor, and I THINK that it tells your tach how fast the motor is spinning. My tach started jumping around erratically this afternoon, I think it is my PIP going south on me. Hopefully somebody more knowledgeable will chime in.
T
toppdogg_1
89
  • Aug 4, 2005
i just looked around the forums some more and found out that it is a senor in the distributor like you said, and that if it is going that it is best to get a new distributor because the sensor may be cheap but you need to tear down the dizzy and then rebuild it after putting in the new sensor
HISSIN50
34
129
Aug 4, 2005
  • Aug 4, 2005
Yep, I wont try to spout off into because I am conversant with the fox PIP and the SN PIP actually works a little differently (it can use the raising and falling edge as a means of calculation IIRC).
The PIP is responsible for base spark and injector timing.
When one has a bad PIP, there should be no spark and no fuel injector pulsing (a bad TFI gives no spark but does not affect injector pulsing).
Some folks breeze through installing a new PIP and some struggle (getting the gear back on and aligned can be a pain). Were it me, I would try to do the PIP (a bearing splitter really helps with the task) and if it wont go, get a reman'd/new dizzy. At some point I would have a machine shop do the PIP in the old one so you have a back up dizzy.
Or a machine shop should be able to do the entire PIP swap.
Good luck.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
  • brandyn200
  • Jun 20, 2026
AeroCoupe
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
