code 41 and 91 help please
  • Thread starter Thread starter Mr. Blues
  • Start date Start date Feb 15, 2009
M
Mr. Blues
  • Feb 15, 2009
searched previous posts for help but so far nothing works for my pony...
1991 LX hatch, 5 speed, basic stocker, replaced both O2 sensors, cleaned MAF, no exhaust leak, idles fine, runs great, acceleration smooth no hesitation, recent fuel install, fuel pressure around 44, cylinder balance = 9. timing = 10, orange ground wire secure to back of motor. any ideas?
thanks for all replies
Black1987Stang
1,422
Jersey Shore
Feb 15, 2009
  • Feb 15, 2009
Reset the fuel trims after you changed the o2 sensors by disconnecting the battery for a little bit?
I don't think it matters except for warming up but you can check for power for the o2 sensor heater, should be 12v with the key on run....that orange wire going to the back of the motor is the ground for it.
If you got access to one I would hook it up to a piggyback w/ datalogging to check the o2 sensors for proper signals (rich lean rich lean)...or you can hook an analog voltmeter I believe to the o2 sensor signal wires (29 and 43) and look for the same thing..just so you know the computer is getting everything it should properly. Besides that im running out of ideas too.
M
Mr. Blues
  • Feb 16, 2009
thanks for your reply. Today I cleaned the pcv and screen, IAB and EGR thingy...no results but they needed cleaning anyway. Tuesday I take it to some guy who says he has a computer that will tell him what the voltages (?) are...hmmm... we'll see.
M
Mr. Blues
  • Feb 17, 2009
Update
Reinstalled drivers side sensor....code 91 disappeared...
Replaced passenger sensor with old "good" sensor..code 41 disappeared
took " bad sensor bqck to auto zone, they will replace at no charge with new one. Hopefully this will be the last hurrah! Thanks for your reply.
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
Engine New to Mustangs, guidance needed on fault codes 47 & 45
  • sUdz6.0pwrstk
  • Sep 30, 2021
4K
Fox 5.0 Mustang Tech Oct 23, 2021
General karthief
